Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
No beep at start up - Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
  • 669 Answers
Could be a grounding issue. Remove the mother board from the case, and place on a piece of cardboard. Plug in the power supply, memory, monitor and power switch if it will reach (if not then you will need to short the jumper were the power switch plugs in with a small screw driver). Once set up, power on the mother board, you should get a no hard drive error, since we did not plug it in. If this does work, you will need to go the hardware store and pick up some rubber or paper washer to place between the mother board and the case.
Posted on Feb 23, 2012
I am getting a beep beep space beep beep space beep beep
if you changed out the start device or orerload and relay and the compressor is clicking you have a bad compressor
Jul 18, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Audible beeping sound when starting car and when driving
parking sensor beep?
if yes then if one of the sensor fails then all system goes off and keeps buzzing
Feb 26, 2018 | 2004 Audi TT
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Sep 24, 2009 | Compaq Computers & Internet
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Jan 24, 2009 | Computers & Internet
Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
Jan 16, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
80 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
