Question about WatchGuard Technologies FireBox SOHO 6 Firewall
Setting up a VPN through watchguard
Hi. I'm trying to setup a VPN on my network in which my employees can acces the server remotely. I am able to remotely access the server through remote desktop connection but currently unable to setup a proper VPN connection from an external site. Our sever runs Windows 2000, and currently use the Watchguard Firebox Soho 6. Please help.
    Novelist:
  • 114 Answers
The key with any VPN solution is to make sure that the configurations on both ends match. I am not very familiar with this particular product, but it looks like you need to have the proper VPN licenses installed first. There are two types of VPN you can do. 1) Site to Site - This is where the are two static boxes that you want to create an encrypted tunnel between 2) Remote User access - This is where mobile users connect to a central site over an encrypted tunnel from their home or on the road. Next, take a looks at the User Guide PDF here: https://www.watchguard.com/help/documentation/soho6.asp Chapter 10 tells how to configure the VPN on the Firebox side. You would just duplicate your settings if your doing option #1. Chapter 11 tells how to configure the VPN on the client side. This section would tell you how to configure the client software for option #2. Hope this helps.
Posted on Sep 01, 2006
    New Friend:
    Problem Solver:
  • 12 Answers
  1. Select VPN > Mobile VPN > SSL.
    The Mobile VPN with SSL Configuration dialog box appears.
  2. Select the Activate Mobile VPN with SSL check box.
  3. Select an Authentication Server from the drop-down list. You can authenticate users with the internal Firebox or XTM device database (Firebox-DB) or with a RADIUS, VACMAN Middleware, SecurID, LDAP, or Active Directory server.
    Make sure that the method of authentication is enabled (select Setup > Authentication > Authentication Servers).
Best VPN Service Find and Compare VPN Providers
Posted on Jan 12, 2015
Can u tell me how to connect two companys in vpn connection through two x20e firebox
Posted on May 10, 2008
How connect cisco 5015 vpn with barracuda linkbalancer 330
Your Internet gateway <--- primary router
Port #1 on primary router <---> VPN server
Port #2 on primary router <--> Load Balancer
Load Balancer <--> web-server #1
Load Balancer <--> web-server #2
Load Balancer <--> web-server #3
VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
Jun 12, 2014 | WatchGuard Technologies WATCHGUARD TECH...
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
Iam trying to log on facebook.com but the computer is blocking me with wacthguard. i try to use many unblocked proxies but it not allowing me to reach facebook and myspace. please help so i log on facebook...
Look into http://www.acevpn.com/ for $5 per month. I would caution accessing Social Networking and File Sharing sites once they are banned by employers, and attempting to find a workaround and accessing them anyways can be grounds for dismissal.
  1. One plan and one low fixed price - $5. The same VPN account works on all the supported platforms and devices. We support OpenVPN, PPTP and L2TP
  2. Connect to any VPN gateway servers on our network at no extra cost. We currently have servers in USA and Europe (France, Germany, Netherlands, UK). More servers being added in different countries
  3. Allows access to banned, blocked and censored websites, applications and services. Use VOIP, SIP adapters, Skype, Google Voice, instant messengers like Yahoo, MSN / Windows Live, Google Talk, etc., social networking like MySpace, LinkedIn, Facebook, Twitter, etc., dating or adult sites even if blocked by your Country, ISP, University or Corporate firewall
  4. 100% anonymous, secure and private. Surf the Net without leaving a trace even on public unsecured Wi-Fi / hotpots
  5. Protects your privacy from behavioral ads and data mining websites like Google Ads, Quantcast. Prevent Identity theft
Jan 11, 2010 | WatchGuard Technologies WATCHGUARD TECH...
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
Aug 17, 2009 | 3Com OfficeConnect VPN Firewall - Firewall...
Cannot connect to company email and network through VPN
Could you please explain me how to you are trying to establish the vpn its a site to site or site to client
another thing if you are connecting to head office through mobile user client behind any natted device you should enable nat traversal in your firewall then only i will works.
Mar 25, 2009 | WatchGuard Technologies WatchGuard Firebox...
Hi my server is blocked with linux server so how can i unblock orkut from it...
Hi ,
Which Firewall are you using . Easier way is to check orkut usinf proxy . check in goole lot of free sites available
Dec 12, 2008 | WatchGuard Technologies WATCHGUARD TECH...
Vpn client
You can download the MU VPN client at www.watchguard.com/support
For instructions on how to install and set it up, this document should be helpful http://www.watchguard.com/help/docs/v50SOHOMUVPNGuide.pdf
Nov 05, 2008 | WatchGuard Technologies WatchGuard Firebox...
Watchguard site to remote offices
What have you done to date, what is the Config on both sides.
Let me know
Aloha
Bob
Jan 19, 2008 | WatchGuard Technologies FireBox SOHO 6...
WatchGuard Technologies FireBox SOHO 6 Firewall Logo
17,566 people viewed this question
Top WatchGuard Technologies Computers & Internet Experts
Marvin
Marvin
Rajendra Singh
Rajendra Singh
Syzys
Are you a WatchGuard Technologies Computer and Internet Expert? Answer questions, earn points and help others
