Question about Hoover U5750-900 WindTunnel Bagless Upright Vacuum
The belt is unstrectable
Belt is too tight is strech
  • donna leitz Feb 22, 2012
    I cannot strech belt too roller
Shampoo part wont stay attached, keep coming apart, brand new about 1 year!
If the tray comes off the machine this is caused by a stretched belt, customers forget get to take of the tension of the belt when not using the shampooer, if left on the belt lifter hook it streches the belt. fit a new kirby genuine goyshan belt
Dec 28, 2015 | Kirby Style F 2009-Newer Sentria Allergen...
Vibrating belt
Binding roller -- streched or wrong belt--
Jan 02, 2014 | Hoover Tempo Widepath Upright Vacuum -...
I cannot find my owner sheet and need to change the belt in my upright oreck
THERE IS A SINGLE SCREW ON THE SIDE OF THE VAC KNOWN AS THE 'BELT DOOR'.
LAY VAC ON IT'S RIGHT SIDE, SO THE BELT DOOR IS STICKING STRAIGHT UP IN THE AIR. REMOVE DOOR AND BELT DOOR. CUT OLD BELT IF IT IS NOT BROKEN. TUCK NEW BELT UNDER BRUHROLL PULLEY FIRST THEN STRECH OVER MOTOR SHAFT.
DO NOT REPLACE BELT BY REMOVING BASEPLATE. 1) THE MOTOR IS NOT STABLE ENOUGH FOR THE TIGHT BELTS WITHOUT THE SUPPORT OF THE MOTOR 2) REPLACING BASEPLATE IMPOPERLY MAKES VACUUMING DIFFICULT. ">
Feb 18, 2011 | Oreck XL21 Bagged Upright Vacuum
My Kirby is not engaging the belt after it was put back on. I took it off to clean brushes and did everything according to the video but the belt will still not engage and green light does not come on.
The belt is not on the motor shaft. Remove the head from the motor unit. With the belt centered on the brushroll, turn the belt lifter a full 3/4 turn counterclockwise to stretch the belt up onto the belt lifter finger. ( Look through the back to be sure the belt is streched into a loop over the finger.) Plce the head back on the motor unit and latch it in place, then turn the belt lifter fully clockwise to drop the belt onto the motor shaft. Be sure the brushroll is correctly installed in the head. Setting # 1 should face the floor.
Dec 19, 2010 | Kirby G5 Bagged Upright Vacuum
The brush on the bottom of the vacuum won't turn when in position to vacuum. I have cleaned the brush, there is nothing tangled around it.
Sounds like the belt is broke, when you remove the brush, be sure that all teeth are still on the belt and that it is not streched. Typically every major retailer will sell these belts usually 2 to a pack and under $10
Jun 24, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Belt installation
You will have to slip the belt over the motor shaft and strech it down to the brush roll that should be loosened from the bearing rest, slip it over the brush and strech brush back into position.
Sep 13, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Burning rubber smell when turned on. checked the belt-is ok.
Take the bottom off as if to change the belt and remove the brush assembly from the VAC. Take the ends off the roller and clean out the string and hair and whatever is wrapped around the end bushings and reinstall. Should free-up the roller Brush and stop the resistance on the belt to motor shaft. Or your belt is streched out and should be replaced, they don't always have to Break to be bad.
Aug 18, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The bar brush does not spin. I opened the vacuum head and the drive belt to the bar brush is loose. I don't see how you remove the slack from the belt.
you have to have it in the carpet setting in order to put pressure on the v-belt. there is no way to tighten up the v-belt, but i would try to replace the big flat belt. if you haven't changed this belt in over 6 months, i would change it. ( on average belts need to be changed every 6-8 months). the reason is that the belt streches over time and doesn't have enough tention to ingage the v-belt in order for the brush to work. hope this helps
Jul 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5750-900 WindTunnel Bagless Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
