Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Replace hoover belt 40201160 - Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
You usually have to unscrew the bottom and take it off to get to the belt and then you have to stretch it back on usually a quick fix
Posted on Feb 22, 2012
I keep having to replace the belt on my Widepath Hoover Temp. Last time, the belt wasn't broken but had come off the spool. How can I secure the vacuum belt and/or stop it breaking? Thanks for any...
First be sure you have the correct belt for the machine. The current belt may be stretched, but not broken. The correct belt is # 38528033, or in a package of two, the package # is 40201160. When you have the agitator out of the vacuum, stand it on end and make sure it turns easily. If it does not spin freely, there may be hair or string in the bearings which will need to be cleaned out.
Jun 21, 2011 | Hoover Tempo Widepath Upright Vacuum -...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
My Hoover doesn't roll
You need to replace the belt. Part number 40201160
Oct 07, 2009 | Hoover Tempo Widepath Upright Vacuum -...
My brushes stopped spinning. what do i do?
Easy enough reference your owners manual and find out the replacement belts, from there if you provide us with the belts part numbers or model of you machine i can have them ordered for you, submit your info here: Vacuum parts
good luck
Sep 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover U5399-900 WindTunnel Vacuum
38528033 is the belt number or just 033.
40201160 is the part number for a 2 pk
sometimes they are referred to style 160 as well
All these are the same belt. Hoover makes things so simple don't they? LOL
Dec 02, 2008 | Hoover U5399-900 WindTunnel Lite Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
