I have a LiteOn LVW-5005X and the remote RM-57 has stopped working (batteries are new), any way 2 fix?
5 Suggested Answers
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
SOURCE: Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Posted on Apr 05, 2009
  • 919 Answers
SOURCE: rm-1 Olympus remote. I have 2 of them and can not
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
Posted on May 11, 2009
  • 4090 Answers
SOURCE: I have a phillips universal remote and I need the
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Posted on Aug 18, 2009
Manual for LVW-5005X CD/DVD need copy Have the Player need manual to hook up to TV
The user's manual is available from Lite-On as a .zip file. http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 Select Audio/Video and then your model number in the two drop down menus; then click Search.
The direct link is http://www.liteonit.com/DOWNLOADS/DC/LVW-5005X/user_manual/en_us/LVW-5005X_US_English.zip .
You will need to unzip the file to read the document. With Windows, right click on the file after downloading and select "Extract All".
I hope this helps.
Apr 30, 2011 | Computers & Internet
I need the access code to configure Universal Remote to simulate the RM-51 Remote for the Lite-On LVW 50005 DVD.
There are thousands of models of so-called universal remotes, each of it supporting a limited number of brands , each brand having just a limited number of devices.
To program your remote you should look in its manual at the DVD player to see if the brand LiteOn is supported. If it is you should check that your exact model is there if it is then the code beside it will be the one to use. If your exact model isn't listed you should try all the other codes from the LiteOn. If none of them work or LiteOn isn't supported you should try all the other codes under the DVD section. If no codes work then your remote simply doesn't support your player.
In that case your only option is to search for another remote that will support it.
Jul 26, 2010 | Televison & Video
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Liteon Dvd VCR Recorder tray has a disc in it but I cant open
CLICK ON START
CLICK ON COMPUTER
RIGHT CLICK ON THE DRIVE IN QUESTION
CLICK ON EJECT
(MAY HAVE TO DO MORE THAN ONCE)
Mar 11, 2009 | Lite On LVW-5005X DVD Recorder
Do i need remote
Yes you can't finalize without a remote.These units use a RM 51 remote.You can find one ebay or you can get a new one at Litetrekinternational.
Dec 21, 2008 | Lite On LVW-5006 DVD Recorder
Remote
You can order a new remote on their homepage by going to the consumer support section.
Aug 16, 2007 | Lite On LVW-5005 DVD Recorder
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
