Question about Gateway GM4019E PC Desktop
Lost red colors on GM4019E desktop..It's not the monitor because I tried 2 monitors that are working and only on this desktop that the color show greenish..When I start the computer the small rectangle that comes on shows the RED GREEN BLUE brightly though, so it means the colors are there? It just happened few days ago...I did not do anything that I recall...I even restore my system back a week thinking any updates might have done it? But it is the same..Please help..I am running Windows 7 Professional SP1 32bits OS.
  • am vail Feb 22, 2012
    Gateway GM4019E is my computer model..
    Guru:
  • 1,705 Answers
If 2 monitors are showing the same picture, your graphics card is at fault.
First, Click on my computer - device manager - check there are no alarms shown by the devices in your pc especially the graphics card.
If none, RMB click on your graphics card, select properties and choose the "Roll back Driver" option.
Second, look on the Gateway website, follow links for support/downloads check that you have the latest driver for your graphics card. Also note the make, model and type of your graphics card. You'll need these if it has to be replaced.
If both have been completed, then your graphics card probably needs replacing. I'd try ebay first for a good second hand. You could take this opportunity to upgrade, just make sure you buy on with the correct interface.
Posted on Feb 22, 2012
The color is not working properly on the computer
Often when colors dissapear the reason is a broken cable, between the computer and the monitor, try another cable / monitor to see if the problem is solved, if not, then the problem is either your graphics card or the settings on your computer, it is possible to adjust them so that you don't get red color for example at all.
Aug 11, 2012 | HP Media Center m7250n (ED842AA) PC...
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
My acer monitor is showing only blues and yellow colors. No reds etc. I tried to adjust it on color resoliution byut didnt work
Try a different video-cable.
Try tightening the connections at each end of the cable.
Try connecting the monitor to a different desktop or laptop,
to see if the colours are correct -- it could be the video-card on your computer.
Oct 29, 2009 | Acer Computers & Internet
The computer has lost all the red color and others
Hook up another known good monitor to the video card and if it still has problems with red then you know the video card is bad and needs to be replaced.
If the known good monitor still works after being hooked up to the video card then you know the original monitor is bad.
Let me know if I can be of further help.
Ben
May 14, 2009 | Gateway GT5220 PC Desktop
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
1 monitor is red - 1 is green
its because when you start putting to many moniter spliters the color data gets lost in the link.
Sep 12, 2008 | Matrox 128 MB G450 Quad Graphic Card
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
Gateway GM4019E PC Desktop Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
