Question about Brother HL-5370DWT Laser Printer
Brother hl-5370dw drum light
Drum light will not go off
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Dec 08, 2008
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Feb 01, 2009
  • 13 Answers
SOURCE: brother hl 2040 printer
This indictes its time to relace the drum.(drum life is up to 1200
copies)
mongrelken.
Posted on Jun 08, 2008
  • 10 Answers
SOURCE: How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Posted on Apr 20, 2009
komguy
  • 2306 Answers
SOURCE: Drum light comes on my Brother HL-5040
You need to reset the drum counter. Open the front door and hold the go button until all the lights flash. Shut the door, ready to print...If you press the go button 3 times it will give you a printout that shows the usage level of the drum.
Posted on Jun 25, 2009
Brother hl 5370 led error codes
pls check it out at http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hl5370dw_us&faqid=faq00000170_019
Sep 06, 2016 | Brother Laser Printers HL-5370DW HL5370DW...
Vertical black line when I print
Try with a new cartridge (that includes a new drum)
otherwise
replace drum
or fuser.
Apr 21, 2014 | Brother HL-5370DW Duplex Wireless Laser...
Have a problem with HL-5370DW Status LED is red &
Hi, if you status led become red and only that light is on must be 1 of the following problems:
1.- Front Cover is opened
2.- Memory Full
3.- Option Tray is installed too much
4.- Print Overun
Sep 13, 2013 | Brother HL-5370DWT Laser Printer
I am using Word 2010 and I can't print labels on my Brother HL-5370DW printer. The red light comes on and it stops. I can't find a front tray for a manual feed. Got any ideas?
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=brother+hl-5370dw+downloads&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.brother-usa.com/Printer/ModelDetail/1/HL5370DW check out support please.
http://www.siliconguide.com/drivers/device/1609/
download drivers
Jan 24, 2013 | Brother HL-5370DW Duplex Wireless Laser...
WordPerfect only prints to manual tray on Brother HL-5370DW
Close WordPerfect. Clear all printers. Go to Registry Edit and browse to HKEY_CURRENT_USER\SOFTWARE\Corel\14 or whatever version you are using and right click on the "PrintEngine" folder and rename it, e.g, "PrintEingineOld." I discovered this shortly after I posted my inquiry.
Dec 16, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5370DWT Laser Printer Logo
1,442 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
