Question about Electric Drills
Find replacement for B&D 1172 3/8 drill switch pn 448300
Defective switch
  • 425 Answers
That was not the part number shown on the parts diagram at servicenet.dewalt.com. The tool is from the 1970s and is obsolete. I doubt you will be able to find a switch for it.
Posted on Mar 07, 2012
Is the Headlight switch for the Chevy Express 2500 defective
The replacement switch could be defective.
Jan 30, 2015 | Cars & Trucks
YTH2448 STARTS OK, BUT SHUTS OFF WHEN I LET OFF THE CLUTCH ?
Can be cause one of three things.
  • Defective operator seat switch or it disconnected.
  • Defective reverse switch
  • Defective PTO switch
Jan 12, 2015 | Garden
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Why when i hit my starter switch on my 1980 harley nothing?
Battery dead, main fuse blown or missing, system/ignition fuse blown, bad ignition switch or not turned on, security system on board and activated, run stop switch "OFF" or switch defective, start relay defective, if hear the start relay click but no solenoid click a defective solenoid, and/or defective wiring between any or all. Good place for a battery condition , cable and terminal etc check and then if good a voltage drop testing procedure to locate source point to problem.
May 31, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
My asko dryer 7005 works the heating element but the drum d,not turn
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Mar 02, 2012 | Asko Dryers
Not drying
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Sep 21, 2011 | Kenmore Dryers
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Solution for "c30 code on Mita DC 1255
A C30 code is as follows straight from the Tech Manual.
.Timing switch fails to turn ON 2.5
sec after scanner motor starts to
turn in normal direction.
.Home position switch fails to turn
ON 6 sec after scanner motor
starts to reverse.
Solutions:
.Defective scanner motor
.Defective timing switch
.Defective home position
switch
Also check the scanner rail some of the seals on the rail around were the motor sits turn to gunk and will stop the scanner assy from moving.
Jul 01, 2009 | Kyocera Mita FS-C5016N Printer
Drills Logo
44 people viewed this question
Top Electric Drills Experts
Are you an Electric Drill Expert? Answer questions, earn points and help others
