Question about Directed Dei Valet 561r Remote Start/Keyless Entry
What kind of battery do i need for valet 0890 remote?
2 Suggested Answers
  • 46 Answers
SOURCE: replace battery in a valet remote start
have to do it within 2 mins....use a knife and split the case open the rest will be simple aftre that
Posted on Jan 14, 2009
How to change the battery in a jaguar XF smart key
1) Carefully remove the plastic silver sleeves on each side of the remote.
2) Carefully open the remote to expose the battery -- try to keep the circuit board and valet release pin from falling out.
3) Replace battery -- plus (+) side down
4) Before closing body of remote, take note of valet key release pin & spring. Be sure the spring and pin are in the correct position (see pic).
5) Carefully close body of remote.
6) Before attaching sleeves to remote body, be sure the notched end of the sleeve is aligned with the valet key.
7) Carefully slide silver sleeves onto each side
8) Test
Apr 24, 2014 | 2009 Jaguar XF
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and now it...
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
Jan 17, 2014 | Directed Electronics 479V Remote Gen 2...
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
I changed my battery and now the car will crank but not start, whats wrong?
What kind of car?????? Does your car have a transponder????
Most likely your remote start/transponder bypass module lost programming due to you changing the battery.
Dec 22, 2010 | Directed Dei Valet 561r Remote...
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Valet 561r remote starter wont start my 2004 gmc sierra
You should not have to... Just start it with a key first.... What are the symptoms, please be more specific..
Jan 16, 2009 | Directed Dei Valet 561r Remote...
Replace battery in a valet remote start
Jan 13, 2009 | Directed Dei Valet 561r Remote...
DvD Player
My remote cannot function with the recorder. Battery is OK
Their is a number 2 digit on the display.
Assistant please
Mar 06, 2008 | Philips DVDR 3355 DVD Recorder
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
46 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
