Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Gu120esjq not draining and water in tray at bottom
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Water in tray on bottom of dishwasher
Have you tried turning on the DW and holding the START reset button until you hear the water begin to drain out. This worked for me.
Jul 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking to bottom of freezer
ok you have a blocked freezer drain. The best thing to use to clear this is 'curtain wire (the plastic coated wire you use to hold up net curtains). Ok you need to find the drain hole in the "small tray on the back wall inside that fills and freezes and then the water is overflowing at this point to the bottom of freezer" you want to gentley feed the curtain wire down the hole untill the water drains down there. If you can't get the wire down you may need to turn the unit off to defrost as it could be frozen solid with ice. cheers
May 31, 2009 | GE Refrigerators
Water collecting in the bottom tray and, at time, pouring out
The condensate drain is probably plugged w/dirt. You have to blow out the drain w/ some pressure to clear the drain.
Apr 15, 2009 | Heating & Cooling
Water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Oct 11, 2008 | Kenmore 16.7 cu. ft. Freezerless...
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
Amana refrigerator 20 condensation water in fridge
moisture in the freezer is condensed at the back in a tray that has a drain with a tube that drains to a tray at the bottom of the unit. In our case the drain was clogged and water froze in it. We removed the back panel and pulled out the tube from the drain spout. We then used a hair dryer to defrost the ice clog and a wire to route out the drain and the tube. This worked and we replaced the tube and sealed it with tape. It now drains properly into the tray.
Sep 13, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
JCD2389DES Water Leak Problem
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
70 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
