Question about Coffee Makers & Espresso Machines
I need a wiring diagram for waring cu55 coffee urn
Waring CU 55
Ya1da
  • 4 Answers
SOURCE: instruction manual
Click on this link
http://www.miele.com/manuals/before_download.asp?id=2&bhcp=1
then c;ick on the download manual button, it will ask you why you want to download, just pick an answer and push download,.... voila you get the manual
Posted on Mar 12, 2008
SOURCE: Faberware Coffee Urn 55 cup
I was able to buy a spigot for my Farberware Coffee Urn FSU236 from Mxim/Toastmaster in Macon, MO PHONE: 1-800-233-9054
Posted on Nov 23, 2008
ginko
  • 19396 Answers
SOURCE: Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Cuisinexpert
  • 61 Answers
SOURCE: We have a waring pro wc1000 coffee maker and it
If you've never done a decalcification, do one. A decalcification basically means that you're running vinegar and water through your coffee maker to get rid of calcium build up, which can cause your coffee maker to run very slowly, or not at all.
You always want to do a "1/3 white vineger to 2/3 water" solution--meaning that if you have a 10 cup coffee maker, you want to fill it 1/3 of the way up with vinegar (3 cups), the rest with water. If you have a 12 cup coffee maker, you want to do 4 cups of vinegar, fill it the rest with water. And yes, it DOES have to be white vinegar--the other vinegar types don't do anything for calcium ;)
You basically just brew the vinegar/water though your coffee maker, and you might have to do it 2-3 times before it will be completely fixed--most companies recommend that you run the vinegar/water through your coffee maker once ever 1 to 2 months to prevent things like this from happening, so if it's already happening, you may have to do it more.
And always remember--after you brew a pot of vinegar/water through your coffee maker, brew a regular pot of plain water through it afterwards, or your coffee will taste like vinegar! lol
If all else fails, you can always contact Waring customer support - their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Posted on Aug 26, 2009
Lady Spark
  • 51 Answers
SOURCE: How much coffee do I use to make coffee in the 55
use 7- 8 0z cups fresh grounds. Time to brew depends on efficiency of urn. Maybe 15-20 minutes on average.
Posted on Feb 07, 2010
Where can i find parts for a regalware k1355 55 cup coffee urn
I have a Regalware 55 cup coffee urn, model #K1355. I do not have a part's list for unit. The part I'm looking for is a small switch. It says WR-I think that stands for White Rodgers. It's a four terminal switch two terminals on each side. The numbers on switch are161491 085n, other numbers on switch are250c, 158E,andTf318c. can you help me find this switch.
Jul 31, 2010 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Apr 16, 2010 | Faberware 12-55 Cup Coffee Urn
How much coffee do I use to make coffee in the 55 cup urn? How long does it take to brew the full urn?
Feb 02, 2010 | Faberware 12-55 Cup Coffee Urn
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
I lost the instructions for using the Waring WC1000 coffee maker-how do I brew a pot of coffee?
JUST LOOK UP ONLINE THE MODEL NUMBER OR CONTACT CUSTOMER SERVICE FOR WARING AT http://www.waringproducts.com/
Aug 22, 2009 | Waring Pro WC1000 Coffee Maker
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
Jul 25, 2008 | Faberware 12-55 Cup Coffee Urn
A short condition has severed a conductor wire inside the coffee maker. Seems to be a common problem with coffee makers as the wires are in close proximity to heating devices.
Mar 16, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Coffee Makers & Espresso Machines Logo
107 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
