Question about ThirtyTwo Prion Fast Track Snowboard Boot Men's
Got Thirty Two boots with Fast Track system 2 years ago and the lace is worn off. Is it replaceable and if yes, can I replace it myself?
I think the model is : M' s LASHED FT Fall 2010
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Cheers
Mikey
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
Worn out to fast at the top end of the throttle,can it be repaired,have already changed 2 over,replacement part or repair , many thanks js SAITEK THROTTLE QUANTRANT
Unfortunately Saitek does not have a repair service therefore no spare parts are available at all.
If your Throttle Quadrant was bought less then 2 years ago you should be able to get a replacement for it from your retailer or from Saitek.
Hope it helps...
Apr 07, 2011 | Saitek Pro Flight Throttle Quandrant...
My Burton Snowboard Boot laces have come detached from the boot. Looking at the Burton website they say that it is from resting my board on my boot. Basically the bottom two laces have become detached. I...
Do you mean the lace eyelets?
if this is the case, you can either sew them back on with thread or hot glue them. if it is the actual laces that came out. Buy new laces and replace them
Mar 01, 2011 | Burton Mint Snowboard Boots (Women's)...
1983 kawisaki GPZ750, sat 15 years
your on the right track there its the starter relay you changed but you may also have a wonky starter
(ie: the starter motor brushed are worn out)
Mar 21, 2010 | kawasaki Z 750 Motorcycles
I have a pair of DC Siloh boots that are a couple years old, and I'm having some trouble with the rapid lace system. The lace on the inside of the leg, which tightens the lower half of the boot, will not...
I have exactly the same problem. I just wounder if you managed to solve it yet? I don't know what to do, but every time I try to put them on I have to struggle for about 20 min! It gets so annoying!
Mar 05, 2010 | DC Shoes DC Siloh Snowboard Boot - Women's
I am unable to loosen the laces on the exterior of the boot. Only the bottom half is loose and the top three laces remain very tight.....as if there is a knot inside the boot lining.
Sometimes if the boots have been well worn the lace will pill inside its tubing and become stuck. The best way to fix this is to untie the jammed lace at the bottom and then pull from the top to remove the damaged lace. You will also need to get a replacement lace from your Burton store to repair in reverse.
Feb 11, 2010 | Burton Moto Men's Snowboard Boots '09
Fuel pump
oop's LOL i got a 93 myself and been through 3 aftermarkets pumps on my truck in 2 years till i bought a friggin new one from the dealer yes they do go out
Jan 15, 2010 | GMC Jimmy Cars & Trucks
Boot open light came on.
Your car is equiped with a sensor to know if the boot is open or not as to worn the driver if it was open. It could be that it came a little loose and needs to 1- be adjusted by a body shop. 2- replace the sensor
Jul 27, 2009 | 2000 Jaguar S-Type
My sons thirty two snow board boot with the boa system wire broke on the slopes. Are there replacement wires for this system?
the website is called www.boatechnology.com once at the address click on the sports tab then select snowboard then scroll down to thiry two. then you will see a list of boots the focus and the prospect ect. lets say he has the focus so you would click on the wording "get replacement lacing and reels" in the upper right hand corner for that specific boot. the rest is up to you to fill out the info.
Mar 08, 2009 | Winter Sports
ThirtyTwo Prion Fast Track Snowboard Boot  Men's Logo
87 people viewed this question
Top ThirtyTwo Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a ThirtyTwo Winter Sport Expert? Answer questions, earn points and help others
