Question about Ruud Heating & Cooling
Missing model #
My unit which is a Ruud gas pack needs a new heat exchanger, my problem is this unit is quite old and the model # on the label on the outside of the unit is faded away. I have looked inside in all compartments hoping to find the model # but there is none to be found, any suggestionss?\
    New Friend:
  • 30 Answers
Try getting the numbers on top of the compressor and taking that to your ruud dealer
Posted on Oct 30, 2008
Gas pack heater sporadic
Is this a package unit?
Nov 29, 2013 | Heating & Cooling
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Ruud gas pack cuts off after a short heating session. Only can start by resetting rollout switch. What could be wrong?
burners could be rusted blocking gas from getting across , so it pockets up and ignites all at once ,there also could be a partial blockage in heat exchanger but this is unlikely, or more seriously the heatexchanger could be rusted out with large holes in it so when blower comes on the positive pressure pushes flame back. either way when the roll out switch is tripped it indicates a pretty serious and potentially harmful issue that should be inspected and diagnosed by a reputible company.
Dec 02, 2010 | Ruud UAMB Air Conditioner
Do you know where i can buy or get a gas blower tube for my ''Ruud Achiever Self-Contained 10 SEER Package Gas/Electric Unit''
Rheem and Ruud are the same equipment, so look on line for a supplier of either brand, they just have the first number of the model number that is different.
What do you mean, when you say, gas blower tube?
heat exchanger, inducer draft motor?
Give me a shout back and let me know.
Sincerely,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
I HAVE A RUUD SILHOUETTE GAS FURNANCE. The pilot light keeps blowing out. When I light the pilot flame it seems to work perfectly at ignition. As the Manual instructs, I hold down the ignition switch for...
Short answer, yes. However you could have another problem. Replace the thermocouple that keeps the pilot lit. You can get a universal one at any good hardware or farm store. Make sure the new thermocouple is well into the pilot flame. If the blower knocks out the pilot flame again, I would be suspecting cross contamination from a crack in the heat exchanger. As the exchanger heats up, it may be causing a small crack to open and allows the blower to extinguish the flame. It may also be causing a leak of Carbon Monoxide into the heated room air. I would get it checked out very quickly.
Mar 07, 2010 | Ruud UBHC Air Conditioner
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Ruud gas pack has stopped heating.
Is it spark ignition or a glow coil? Sounds like the ignitor is busted. If it was a roll out switch the fan would stay on trying to cool off the switch.
Feb 24, 2009 | Ruud UAMB Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
Ruud centeal electric
Is this an older gas heat unit? If so, you may have a burnt out heat exchanger, this can be dangerous.
Dec 10, 2007 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
