Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
Dg7000b no power
Motor runs but no power
Isuzu Rodeo 2001 front wipers stopped working
Can you hear the motor running? If not check the fuse first. If the motor runs but the wipers don't move then the transmission has failed. If the motor isn't running and the fuse is good then the next step would require you check for power at the motor. If there is power (with the switch on) then motor is bad. If no power then probably the switch is bad.
Oct 31, 2016 | Isuzu Cars & Trucks
Tip
How to replace a run capacitor
A Run capacitor has 2 terminals, they go to the Run and Start winding terminals, in this case the Line 2 leg of power is wired to the Run terminal on the run capacitor, that is due to the fact this is a single speed motor and speeds are on the Run winding, had there been 2 speeds, the Line 2 leg of power could not be wired to the Run capacitor but would be going to the High or Low speed terminals, conversely the Run terminal on the compressor can accept only 1 lead.
All electric motors get 1 leg of power directly to the Common lead, the remaining leg of power Always goes to the Run winding or speeds on the run winding if a multispeed motor.
Some compressors have a shared capacitor with 3 terminals, they share the leg of power to their Run windings however to Hermetic it will be say 30 MFD and to Fan it will be say 5 MFD, but as to capacitor theory they get Run and Start Always
Power can be wired to Run on the capacitor as long as the motor is a single speed.
But power ALWAYS goes to Common directly while the remaining leg of power goes to the Run winding or Speeds on the Run winding as in High and Low speeds.
on Oct 14, 2013 | GE 1 Pcs. Of 50uf 370v Ac Motor Run...
Room fan operates continually
the capacitor is correct for the motor
all it does is supply an over voltage burst to start the motor turning, then to keep it running while the switch is on
if the capacitor was faulty in the original motor then the motor will burn out as that over voltage is not there but the current to run the motor is so the motor over heats and burns
as to the constant running it is important to check how you attached the wires to the new motor as you may have a power wire direct to the motor instead of through the switch control
May 14, 2016 | Televison & Video
I have a dewalt dg7000b ..is it normal to have a flame like a little salamander out of the muffler
No. Sounds like the engine is running very rich and unburnt fuel is being ignited in the exhaust pipe.
Dec 13, 2012 | Cars & Trucks
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
When using a 5 pin relay what wires connect to pins 30,85,86,87 and 87a to run a motor using a switch
85 and 86 are your coil wires. If you are using a standard single pole switch, you can run power to the switch, and back out of the switch to pin 85. Ground Pin 86.
Run main power for the lift motor to pin 30, make sure to fuse this accordingly, no more than a 30amp fuse if this is a standard 30amp SPDT relay.
Run pin 87 to the motor's power input. 87A is not required. This is wiring is just to power the motor in one direction.
Jun 07, 2012 | Cars & Trucks
Wipers don't work. motor ok . fuse ok. no power to motor. I can jump power to motor and the wiper will come on by switch.on low
Not sure exactly what you mean. Do you mean that when you run power to it you can turn the wipers on and off with the switch, or do you mean that the motor just runs when you run the power to it? If you mean that it runs automatically when you run the power to it, I would suspect the switch. If it works with the switch, it sounds like a wiring issue.
Feb 14, 2011 | 1995 Buick LeSabre
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
Fan does not turn but motor seems to be running fine
Rain should not affect an outdoor unit. It is designed to be outside. The motor that you are hearing... could this just be your compressor running? If the condenser fan is not operational the compressor will run much louder. TURN THE POWER OFF! See if the fan will spin freely if it is pushed. If it doesn't replace the fan motor. If it does you need to check the power at the contactor going to the condenser fan motor. This is 220 volts BE CAREFULL.. If power is going to the motor and the motor is not running... Change the motor and capacitor. If no power is going to it it could be a bad contactor.
Good luck....
Apr 11, 2009 | Goodman CKL24AR24 Air Conditioner
Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
48 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
