Question about liftmaster Garage Door 1/2 Hp
I have flashing green light on the wall control panel and the door will not open.
    Guru:
  • 1,705 Answers
At a guess, you have to re-teach the power unit to read your remote control. First check there's a good battery in the remote control.
Without instructions, I can't say but here's the url to liftmaster, just enter your details to get to the correct instruction set.:-
http://www.liftmaster.com/consumerweb/service/manuals
Posted on Feb 22, 2012
Garage door opener wall panel light flashing
the lock is turned on. On the wall switch press and hold it for a count of 5. the light should stop blinking
Sep 26, 2016 | Building Materials
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
Garagedoor opener fixed on wall will will open and close door. but will not work from the remote. problem my be because little green light flashing permanently. what is solution
Your opener is in the lock mode. Press and hold the lock button on the wall control for 3 seconds. This should stop the flashing of the light.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Green light flashing and opener button does not work
It sounds like your wall control is bad. Remove it from the wall and then remove the two wires on the back. Remember which wire goes where as they are color coded.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
liftmaster Garage Door 1/2 Hp Logo
280 people viewed this question
Top liftmaster Building Materials Experts
Terry Smith
Level 1 Expert
David Payne
David Payne
Glenn Mayer
Glenn Mayer
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
