Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Can't get the Aging Patterns to Stop
I replaced the lamp and while in the Mute 182 diagnostics, I looked at the various Options. Now I can't get the Aging Patterns to stop appearing every time I power up the television.
I can get the Aging Patterns to go away if I work with it ... but its back again the next time i power up.
Must be something simple. TV works fine ... good picture.
  • 2 more comments
  • Ptuii Oct 29, 2008
    The solutions did not work.
    There is no SAVE button on the screen.
    I hit bot the ENTER as well as END buttons and I can see the timer light going on and off rapidly like something is being saved ... but its not.
    I unplugged the set for 30 minutes ... no change. When I turn it on and get back to the diagnostics screen, the Aging Patterns is lit up in yellow like its waiting for some type of intervention. I've tried going to User Reset and then going through Enter and End and Off/On ... no difference.
    How do I get out of Aging Patterns on the diagnostics screen?
    Thanks
    4-5hours should be long enough if it is processing. It wasn't.
    I am suspecting just as Mute 182 turns the service menu on, there is another button pattern to save and exit the service menu. Note I have previously referred to the service menu as a diagnostic screen.
    Still looking for a solution that works ... saves and exits the service menu.
    Steps 4 & 5 have on affect on the service menu.
    Only the up and down arrows move the cursor to a different Options item.
    Every time the TV is powered up, it automatically opens up with the Aging Pattern option highlighted. Clearly the service menu is not closing.
  • Ptuii Oct 30, 2008
    Team was helpful. Service Menu has stopped appearing although I'm not quite sure why. I think the solution involved one of the following: 1.) Hitting the Menu button twice 2.) Hitting the Menu button then the Mute button or 3.) Allowing the Aging Pattern to stay on for several minutes while it ran completely through it's processing routine.
    Whatever the solution, I am appreciative for the help provided by the Experts on this site.
    Sergeant:
  • 306 Answers
U will have to unplug ur television for sometime and then plug it.. tis problerm may also appear due to irregular power supply.. if not the problem is inside the TV. so don delay ,,approach a service man!!
Posted on Oct 29, 2008
    Genius:
  • 1,226 Answers
Your TV maybe is in the process of adjustment..please use your tv for a long period of time maybe soon that will set to normal.
melnavz
  • 905 Answers
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
  • 5 more comments
  • jason Oct 29, 2008
    if this does not work then you have different problem than just trying to exit the adjustments
    have you followed these steps exactly?
    when you turn it off turn it right back on
    try this ,Save settings and exit by pushing {MUTE} twice then {POWER}.
    steps 4 and 5 are not available on your set
  • jason Oct 30, 2008
  • Samsung Master
  • 19,396 Answers
Go to the diagnostic menu and save.
Try also unplugging the TV for some time, to reset it , in case is stuck with the diagnostic menu.
Posted on Oct 27, 2008
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Bought this TV used and was told it needed a ballast board. I spoke with the tech that worked on it and was told a supply board as well as possibly needing a new bulb. I've replaced all three with no...
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Aug 17, 2011 | Samsung HL56A650 56 in. TV
    The info states this TV has an HDTV tuner (ATSC), however I am unable to tune any digital channels which are broadcast via our cable provider (not offered on whole number channels, rather decimel points...
    You need to reset you tv to factory mode, by pressing tv off---mute 182 power---go to options and look for *reset to factory* them wait until the process is done.
    Dec 19, 2010 | Samsung HL-S4266W 42" HDTV
    I have an HL- t50756 and it turns off every 10 minutes
    Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE
    then punch in the numbers 182 then POWER in that order, wait when the TV starts up the Factory meneu will appear go to Options press, then look for Lamp Hrs. to see how many hours you have on your lamp TV lamps last appox 2 years average use. 4,000 hrs. Try this, above where you see the hours go to reset or something like that and press to reset blub timer to zero. Your blub might still be ok, but the timer says times up and tries to shut off the TV thinking the blub is bad. By reseting the blub timer to zero the TV will think it's a new lamp. Until it really goes then no picture at all or gets very dark. Try this trick it might solve your problem.
    Good Luck!
    Oct 12, 2010 | Samsung DLP HL-P5663W 56" TV
    How do i reset lamp timer Model #HL-S4676-SX/XAA Samsug tv
    Hi:
    Using the original remote, while the unit is off hit the Mute key then push 182 then the power button, this will take you into the service mode, use arrow keys to scroll down to different options and push enter, do this until you see lamp reset push enter to reset, then turn power off to exit service mode.. Do not mess with any other settings in this mode.
    Jan 21, 2010 | Televison & Video
    Need to reset the Lamp counter.in my Samsung HLR5667W
    here you go here is this web site where you can see how to reset your lamp
    Jan 15, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
    How do i reset lamp hours?
    You have to go into service mode to do this. Hit mute on remote then 182 then power button. Unit will come on in service mode, look through each option by pressing enter until you see lamp timer and press enter to reset. turn tv off to resume normal viewing. Please do not change any other settings as this could mess up ur television if you do not know what the functions are. Press the select or enter key to open an option menu for any of the options listed. Use the up down keys to highlight different options. Look for Lamp Clear option and press enter on arrow key to select
    Oct 07, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
    Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
    142 people viewed this question
    Henry  Thomas
    Henry Thomas
