Question about Weather King 10AJA4801AH Air Conditioner
Freez up at the tube going to the fan blower unit
This is weather king 4 ton A/C unit, model # 10AJA4801.
Please help. A friend of mine said it needs new coil
thanks
dan
  • sadhuta Oct 30, 2008
    Looks like the best solution.
    I will check it out the filter and dirty coin and will also check for leaking freon
    Thanks
    Sadhuta
    New Friend:
  • 30 Answers
It is either low on freon or the airflow is blocked. check your filter first. then see if the coil is dirty. saying it needs a new coil because it is freezing is an expensive guess unless he did a freon leak test.
Posted on Oct 30, 2008
Is Wather King model10JA801 a 4 Ton unit?
you are missing some numbers after the JA and with the 8 in there I would say you are missing a 4. That would make it 10AJA4801 which would be a 10 SEER 4 ton
Aug 22, 2014 | Weather King 12AJA4801AH Air Conditioner
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Im buying a ac unit model number is 10aja4801 is this a four ton unit
units are measured in btu's there are 12000 btus per ton. there is a number in the model number that is divisible by 12. the 48 in your model number indicates that it is in fact a 4 ton
Sep 07, 2012 | Heating & Cooling
HOW MANY TONS IS THIS UNIT WEATHER KING 10AJA4801AH?
It's a 48,000 BTU AC - so 48,000 divided by 12000 = 4 tons
Note: 12000 BTU = 1 ton of air conditioning
Jun 10, 2011 | Weather King 10AJA4801AH Air Conditioner
I have 2 Weather King units model numbers 10AJA2501 & 10AJA6001 and am trying to determine the sizes and SEER ratings of each
Hello Larry Both units are 10 SEER.Standard rating ,not efficent units.JA25 is a 2 ton unit,JA60 is a 5 ton unit.Thats 24,000 BTU & 60,000 BTU.I hope that helps.
Jul 08, 2010 | Weather King 10AJA2501AH Air Conditioner
Compressor freezes up at night and some during day.
You are being ripped off. The ambient (outdoor) temperature at night is low and therefore proper condensing does not take place causing the refrigerant to pool in the condenser and starving the evaporator. This causes a lower temperature in the evaporator resulting in "freeze up" which is often mistaken for a loss of refrigerant.
The proper thing to be done is to block off the condenser air causing the high side pressure to rise until the eqivillant of 110*F condensing temperature.
You can also install a low ambient kit which will cycle the compressor off when the temperatures fall
Jun 07, 2009 | Weather King 12AJA4801AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Fan not blowing
is it the condenser fan or inside blower???
Apr 26, 2008 | Weather King 10AJA2501AH Air Conditioner
Open Questions:
Weather King 10AJA4801AH Air Conditioner Logo
182 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
