Question about Sentry Fireproof Safe
Changeing the combination
How do i change the combination
I have the same problem, and looked on the company web site for an answer. According to the Sentry FAQ, we should call their customer service line at 1-800-828-1438 Monday-Friday 8am - 6pm EST.
Posted on Jan 24, 2009
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
Need instructions on changing combo
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
COMBINATION CHANGE
No its a fixed combination from the factory,
you cant change the numbers or sequence.
Jan 28, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
The door must be open.
On models with the passage feature, make
sure the passage feature is disengaged: turn
knob or key should be in vertical
position (A) (see figure 14-1).
1. Insert the DF-59 control key (B) into the
combination change plug assembly (C)
and unscrew the cylinder by turning the
key counterclockwise. Remove the combination
change plug to gain access to
the combination change sleeve (see figure
14-1).
2. Turn the outside knob once clockwise
(all the way, until it stops) then release.
The latch should not retract (see figure
14-4).
3. Enter the existing combination. On new
installations, use the factory-set combination:
depress 2 and 4 simultaneously,
(release), then 3 (release). You should
feel a slight click as each button is
depressed.
4. Insert the spanner wrench as shown in
Figure 14-2 to engage the combination
change sleeve (A). Gently turn the
spanner wrench clockwise to the stop
position (a slight click should be felt),
then turn the spanner wrench counterclockwise
to the stop position (A) (see figure
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
the way until it stops, then release. The
latch should not retract (see figure 14-4).
6. Choose your new combination, write it
on page 26, then enter the new combination
— depress buttons care-fully
(a slight click should be felt as
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
My master lock 1547 lock combination was changed and i cant open it
If you have the change key, you can insert into the lock and make a new combination. Only the Change Key witll allow you to change combination.
Artgirl
Jul 16, 2008 | Master Lock 5400d: Portable Select Access...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Apr 24, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
119 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
