Question about Motorola Mobility MOTONAV TN20 GPS Receiver
Why doesn't Hawaii show up in the list of states on my TN20 GPS?
Tip
Motonav TN20 Firmware Download
Motorola Motonav TN20 Firmware Download
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware. Satellite reception is also improved with newer firmware.
Follow these steps to download the firmware / system software of your Motorola Motonav TN20:
1. Head to Motorolas webpage to download the system software.
2. You will presented with this screen:
3. Find and enter your Motonav's serial number. Review the picture below to find the correct number on the label.
4. Pause for moment and consider the Purchase Date. If you enter a date here beyond the covered warranty period of your Motonav TN20, you will see this screen:
Since the default year of this screen is 2007, I recommend choosing a more recent year. Many people complain that they didn't notice this and get themselves locked out of what they should be entitled to.
5. Enter the Purchase Date, click Submit, and save the file somewhere on your computer.
The software download procedure is now complete. Follow these steps to install the new system software for your Motorola Motonav TN20.
I hope that helps.
_______________________________________________
Motorola Motonav TN20 Manual Download
Motonav TN20 Firmware Fix
Motonav TN20 Upgrade Manual
on May 06, 2010 | Motorola Mobility MOTONAV TN20 GPS...
Tip
Motorola Motonav TN20 Firmware Fix
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
on May 04, 2010 | GPS
I need to upgrade the tn20 gps
Go to this link... I just saw upgrade listed not too long ago... Good Luck!
What to download:
http://www.motorola.com/support/v/index.jsp?vgnextoid=8d756d755961e110VgnVCM1000008806b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
How to download:
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/MOTONAV%20TN20/US-EN/_Documents/Static%20Files/MOTONAV%20Web%20Download%20Install%20Instructions%20v8.pdf
Sep 18, 2009 | Motorola Mobility MOTONAV TN20 GPS...
How do I get a map of puerto rico & install it to my motorola tn20.
Go to the Motorola .com site and download the maps you require . There is a fee. Good luck
Aug 22, 2009 | Motorola Mobility MOTONAV TN20 GPS...
Tip
Download Motorola Motonav TN20 GPS Manual
Models: Motonav GPS TN20 / Motonav GPS TN30
Have you misplaced your Motorola Motonav GPS TN20 Manual?
Would you like a digital, searchable, pdf version of the Motorola Motonav GPS TN20 Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility MOTONAV TN20 GPS...
Instal philippine map or standard world on TN20 gps
I would try Motorola.com for the maps. No idea of how to buiuld maps.
Aug 03, 2009 | Motorola Mobility MOTONAV TN20 GPS...
Tip
I hope that helps.
Tip
Download Motorola Motonav TN20 Upgrade Manual
Have you misplaced your Motorola Motonav TN20 Upgrade Manual?
Would you like a digital, searchable, pdf version of the Motorola Motonav TN30 Upgrade Guide?
Follow this link (& click FREE) to download a pdf version of the Motorola Motonav TN30 Upgrade manual.
I hope that helps.
Motorola Mobility MOTONAV TN20 GPS Receiver Logo
Top Motorola Mobility GPS Experts
Are you a Motorola Mobility GPS Expert? Answer questions, earn points and help others
