Question about Sony Computers & Internet
I have a Sony vaio laptop and the screen is white. I checked the connection (wide ribbon) going from the base into the screen and it still didn't resolve the problem. any other ideas why? thanks! could the cable be an issue?
  • 44 Answers
SOURCE: Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Posted on Dec 18, 2007
flipbooks
  • 177 Answers
SOURCE: How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Posted on Feb 07, 2008
SOURCE: Connecting a sony Vaio vgn-fe570g laptop to a Samsung Monitor
There is an issue with the vga port on 2006 - 2007 sony vaio laptops. It doesn't push enough power to samsung lcds. There are all sorts of complicated solutions suggested by all sorts of people. Don't waste your time. Get yourself a connection cable with gold contacts and you'll be straight. It costs approx. $33.99. I got this one and it works fine (and I have a weak-*** TZ):
http://www.circuitcity.com/ssm/Nexxtech-VGA-SVGA-Monitor-Cable-6-N6VGASVGA/sem/rpsm/oid/192558/catOid/0/rpem/ccd/productDetail.do
Posted on Nov 04, 2008
yboyandrei
  • 828 Answers
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
Posted on Sep 02, 2009
SOURCE: I am using Sony Vaio
Hi....Just check the sound with stereo headset.If it is working properly ,right speaker has to be replaced.If the situation persist same before,you may have to check the motherboard .
Posted on Aug 12, 2011
Sir, i want to my laptop Sony vaio
white screen indicates either:
i. lcd cables gone bad.
ii. the logic board fried.
neither, you should replace the whole lcd.
Oct 10, 2013 | Sony Vaio Vgn-c290 13.3" Lcd Wxga Laptop...
Sony Vaio E series laptop not turning on
check your ram slot.check your bios setup.or reset it.remove your battery press power button 3/5mnt and connect ac power now power on.
May 30, 2013 | Sony VAIO EB Series White Notebook...
I drop my sony vaio vgn-nw120j and the screen will not go on
1) Check your laptop works by hooking up an ancillary screen to the VGA port on the back.
2) Assuming that's OK, your screen is either broken or a ribbon connector has become detached, either way you have to dismantle your laptop.
3) Check the screen ribbon connectors are properly connected to both your motherboard and the screen, if its been jolted loose, reconnecting should be the repair. Give yourself plenty of room to work in.
4) Then its onto replacing the screen, fairly straight forward if you're practically minded. But to get an idea, log onto "youtube" and search for screen replacement video's. There are quite a few, watch at least 2 or 3 to get an idea of what you're up to.
5) Buy a generic replacement, its likely to be a lot cheaper than a Sony specific part, check on ebay and other online shops to get an idea of the price.
6) Before you buy, ensure its compatible with your laptop.
Jun 04, 2012 | Sony Laptop Lcd Screen For Vaio...
The screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
UX280p White Screen
I do agree this is problem
but on doing repairs long ago
i have had simular problem
there is a fine cable that connects
screen to base of your pc /ext laptop
there is posible break in wire
sorry cant help more
Jul 14, 2009 | Sony VAIO VGN-UX280P Notebook
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Nov 22, 2008 | Toshiba Satellite M65-S9092 Notebook
Wide Screen
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Jun 16, 2008 | Sony VAIO VGN-FJ270/B Notebook
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Open Questions:
Computers & Internet Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
