Question about Canon ImageCLASS D1120 All-In-One Laser Printer
Imageclass d1120 toner cartridge problem
The toner cartridge is acting like it's running out, but there is no error message saying that it's low. It will make one or two legible copies before producing an almost blank piece of paper. When I replaced the toner with a new cartridge, it kept giving me an error message saying to "set toner cartridge again" so I eventually put the old one back in. This all started when someone didn't know how to clear a paper jam and tried to continue making copies despite the jam. What should I do?
4 Suggested Answers
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
vipin_yadav1
  • 80 Answers
SOURCE: Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Posted on Dec 20, 2008
SOURCE: set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Posted on Dec 31, 2008
What does it mean when an error message says to load paper :A4
You have the copier set for A4 type paper but it sounds like you are wanting to use 8.5 X11.
Chanmge that setting in the menu
Aug 20, 2014 | Canon ImageCLASS D1120 All-In-One Laser...
The device will not copy or scan. The display says check document but there isn't a document in the device
Try to reset the machine by unplugging the computer cable in the back of the D1120, wait about 30 seconds and plug in again. Should reset the system.
Sometimes when it keep saying jam, I remove the toner cartridge and then put back in. That works also to reset the system.
This is really a great machine with it's little querks, but for the most part, we get along pretty well..... hope this helps. :-)
Leslie
May 19, 2014 | Canon ImageCLASS D1120 All-In-One Laser...
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Install Cartridge error on Canon D-320 Copier
Try opening the right door and re-closing it to reset.
Also, be sure that your "new" cartridge is really new and not a low quality refill.
good luck
Dec 05, 2009 | Canon imageCLASS D320 Digital Copier
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
125 people viewed this question
old marine
old marine
