Question about Kenmore Elite HE5t Washer
Code F71 kenmore elite he 5th steam - Kenmore Elite HE5t Washer
    Sergeant:
  • 316 Answers
geemarie
  • 876 Answers
SOURCE: Kenmore Elite H3 Error Code F71
The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
Posted on Jul 31, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite 3t washer with code f71
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite 5t washer with code f71
oldTech2332
  • 2341 Answers
SOURCE: What do the following codes
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Posted on Aug 18, 2011
oldTech2332
  • 2341 Answers
SOURCE: Kenmore Elite HE 3t steam washing machine shows a
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Posted on Oct 20, 2011
Kenmore Elite HE 3t steam washing machine shows a code of F71
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
Gene
Aug 18, 2011 | Kenmore Washing Machines
What does error code f71 mean?
F71 means it is an Central Control Unit(CCU) communication failure.
http://www.fixya.com/support/r6709094-whirlpool_duet_f70_f71_error_codes
There is an detailed article by one of our senior experts in the above link.. Kindly look into the same.
Mar 03, 2011 | Kenmore Elite 45986 Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have gotten F70 and F71 messages and the door will not open. What do I do about this?
Hi.
Regards.
Ginko.
Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
No communication between UI and CCU
Hi.
I think that by this time you already fixed the problem. The codes indicate usually a fault that is either CCU or MCU.
Regards.
Ginko.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
93 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
