Question about Hardware & Accessories
Install ge timer model 15136 - Hardware & Accessories
2 Suggested Answers
  • 5245 Answers
SOURCE: GE 15136 timer display stopped working
Try resetting timer, and reprogramming.
The GE brand of electronic box timers is not dependable long-term product. The 30-40 amp contact ratings do not appear consistent with rest of timer quality. I think the amp load is overrated from what I have seen, compared with heavy duty timers like Intermatic GM40AVE series etc.
My local home depot has replaced the GE line of box timers with 100% reliable Intermatic T100 series mechanical timers.
http://waterheatertimer.org/GE-timers-and-manuals.html#15136
15136 is not battery-operated timer, and there are no repair parts.
15136 timer is rated outdoors, with temperature range -40F to +130F, which sounds like hardened electronics.
But often these cheaper electronic devices with plastic gears and multi-voltage are not hardened for years of dependable service as found with commercial grade timers.
Nor are they protected from surge caused by local power outage or nearby lightning strike.
For most dependable timer, and cost effective, choose T100 series or T170 series with skip-a-day... repair parts available... timer will last decades
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Gene
h
Posted on Nov 23, 2013
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
I need a model 15440, GE heavy duty digital timer manual
I do not recognize that timer model number.
The only place the model number appears is on link to fixya... indicating that the model number does not correspond to known product, or that some seller has renamed a timer so his product cannot be comparison-shopped.
Re-post question and attach photo
Most GE manuals appear on following link: open link to find same-similar timer
Gene
Water Heater Timers Save Money
Mar 13, 2015 | GE Hardware & Accessories
Gene
h
Nov 23, 2013 | General Electric Hardware & Accessories
Timer for GE Model YLT-15
Timer is not identified:
More information needed
Add a comment with clear description of timer.
Copy following link to help identify timer, and download possible manual
Oct 07, 2012 | Hardware & Accessories
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
http://waterheatertimer.org/How-to-set-timers.html
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
How to ground a Tork EW103B time switch wired for 240Volt since there is no ground lug in the plastic housing or on the body of the timer itself
Many plastic timer enclosures do not have ground screw.
Simply join the ground wires inside wiring space using wire nut.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#ew
Since the timer mechanism is plastic, it is non-conductive.
It's like using all-plastic electric drill. The drill does not have ground wire because the electrical components are housed completely in non-conductive plastic.
You can buy the Tork 9000A metal Nema3R enclosure if grounding is preferred. Or buy Intermatic 2T511GA metal Nema3R enclosure plus buy Tork IAP adapter to fit Intermatic enclosures.
Choose the metal enclosures when conduit needs to be supported and timer could be hit by some object.
The non-grounded box and non-grounded timer is also true of GE digital timers 15132 and 15136. Which coincidentally have same wiring as EW103 when using 240Volt.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
However the Tork DTU40 timer has ground screw >>> but the timer is not grounded, so ground screw is merely for joining wires together.
http://waterheatertimer.org/images/IMG_2232-Tork-DTU-timer-600.jpg
Jul 31, 2012 | TORK Hardware & Accessories
Installation of GE Timer #WB19X10006
Timer number does not match with known GE timers.
Open following link to identify timer and download manual.
July 2011. Add a comment with model number and voltage you are working with and type of Load you are controlling, and I will respond back with information if available.
Jul 22, 2011 | GE Kitchen Ranges
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Installing new GE Mechanical time switch model 15351. Require assistance on how to wire (where goes the black wire (power) and the white wire.
Open following link to identify timer, and then add a comment saying what terminals show on timer, and what voltage you are using, and what load you are controlling.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Jun 26, 2011 | Hardware & Accessories
Manual needed
You can download your manual from the following site as a pdf file. It lists as an install guide but has the set up information. You may need to do a search using your model number.
http://www.jascoproducts.com/support/timer-quick-start-guide.asp
May 29, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Hardware & Accessories Logo
418 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
