Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidare front loader washer error message 20
How to fix error message 20
  • Anonymous Nov 20, 2008
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Posted on Oct 31, 2008
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 Washer stops, beeps and is still wet. What's up? No error codes chart is found on frigidare website.
you need to go to your pump and clean it out..its probably full of change and hairpins and stuff like that....
Dec 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error code 20 Frigidare front washer won't spin water all over floor
error code 20 is a drainage issue,check the drainage pipe at the back of the machine if its kinked or blocked,also check the pump filter behind the front panel underneath the drum at the front of the machine if its clogged,unclogge. if after you unblock the drain pipe and clean the pump the problem still persists then the pump is bad,if you cant do it your self you can get a tech to clean it for you.hope this helps
Jan 10, 2010 | Frigidaire Washing Machines
Washing machine front loader has OE error code
Mine did the same and there was a 20 cent piece in the drain filter which is located at the bottom front left hand side you take off the cover - beware that a lot of water may come out - have towels ready. or your outlet pipe may be blocked. OE is a draining error message
Aug 22, 2009 | LG WM-2277HW Front Load Washer
I had to replace my keypad display after it got fried by the steam. Call Fridgidaire and let them know you've seen numerous people on the internet with the same issue and they should cover it under warranty. The part #154554401
Jan 08, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
489 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
