Question about Toshiba 36A41 36" TV
Toshiba 36A41 Bad Gun or Driver?
Hi I have a Toshiba 36A41 that started to make a loud poping noise in the tube. It also displayed angled raster lines and got very brite. Powering off on produced a flashing power led, and nothing elense. The set after sitting did power on but the picture is now heavy green. I DL the service manual and tried to reset the white balance. When cycling through the values for each driver (for the guns) Green and Red are fine, as in you can go to their max. When adjusting the Blue value it on 3 ocasions produced the same poping on in the tube and produced a high tone. Reducing the value (turning down) would stop the problem. The thing is I cant produce white with the lower values. So is the problem in the Tube or can it be the driver circuit for the blue gun screwing up? Also when adjusting the 5 values RCUT GCUT BCUT GDRV BDRV, is there a set sequence that should be followed? I get what I think looks good but when I check a thin horazontal line which should be white if adjusted properly, its always a different color. Im just wondering if there is an approach to acheaving the desired balance. Thanks
    President:
  • 3,130 Answers
Sorry to say but your tube is bad. It may be able to br rejuvinated with a CRT restorer machine but its not always the case. Good Luck
Posted on Aug 29, 2006
My starter won't work just one click noise when I try start my harley
A LOUD single click, sounding the the started is initally engaging and then does nothing?....that would be a bad starter clutch.
Is it a fairly loud rapid clicking noise like a machine gun?....that would be low battery CURRENT to starter, faulty battery.
Is it a quiet single click?....that would be a bad starter relay
Mar 30, 2013 | Harley Davidson Motorcycles
Vizio model vx322 hdtv10a is losing sound and makes a loud humming noise and a poping sound every few minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | Televison & Video
Toshiba 36A41 pops when I change the channel and I can not adjust color, brightness, etc,and remote does not turn off tv.
The symptoms you describe is the main processor controller is about to fail, when that happens the tv will eventually become unuseable. if the set is more than 5 to 10 years old you will be further ahead to replace the set.
Sep 15, 2011 | Toshiba 36A41 36" TV
TOshiba 36A41 CRTTV has a color problem, i can not see the color Blue.
If it got like that gradually suspect a low emission condition on the Blue gun inside the picture tube, this condition can sometimes be fixed by running a gun cleaning procedure, this is done with a crt analyser device at a repair shop. The other cause for a no blue picture could be a Blue color output that has stopped working, the loss of blue is suddendly when the color out fails, it could also be a problem in the signalprocesing circuit. I suggest having it checked by a tech because it would be something you could not check, first because of lack of equippment and second, you would need some technical troubleshooting skills to do the job.
Jan 28, 2010 | Toshiba 36A41 36" TV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Yellowish monitor display
You have no blue gun transmission. Check your work around the tube and make sure you have good connections. Ohterwise it's in the blue gun circuitry.
Feb 13, 2009 | Toshiba 36A40 36" TV
Vacuum making loud noise (like hole in tube)
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Nov 13, 2008 | Kenmore Progressive Bagless Upright with...
Audio problem with Toshiba 36A41 TV
Try connecting the cable directly to the tv rather than through the VCR.
Mar 25, 2008 | Televison & Video
Toshiba 32cf650
hi there, there maybe a arcking of high-voltage form the FBT. or an amplifier section problem, do some test and check-up. ty
Jan 10, 2008 | Toshiba CF32H50 TV
Pic Bleeding
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured. this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits. if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. but if you dont know anything about this, just bring it to a qualified service technician. good luck!
Jan 21, 2007 | Sony KV-35S45 35" TV
Toshiba 36A41 36" TV Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
