Question about Kenmore 92002 / 92004 Kitchen Range
Kenmore range- oven won't heat
The electronic display panel made some additional clicking noises, but there is no error message. The oven will not heat and/or broil. The elements are fine. It is only a few years old. The burners work fine. This is an electric range. The model # is 665.92142300. Any help or ideas would be appreciated. Thanks.
5 Suggested Answers
  • 109 Answers
SOURCE: Kenmore Oven - neither the bake or broil work, dial doesn't light
these elements burn out over time so chk. that out
Posted on Aug 23, 2009
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore range oven model 880, broil element stays on
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
The front panel keeps showing F10 Err message ?? And it won't stop beeping, any idea what it could be??
The F10 error code means that was a runaway over heating that occured in the oven. The things that could cause the over to overheat to the exterme of the F10 error code reqirements is during self clean normal cleaning temp. IF it wasn't cleaned just before the F10 error code,first the oven temtature sensor needs to be replaced then if F10 comes back after the sensor is replaced the computer control board needs to be replaced.
Gene
Aug 16, 2011 | Kenmore 46713 Stainless Steel Electric...
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric wall oven will not increase in heat after the setting has been selected. The display is held at a constant 100 degrees; which normally increases as the oven heats up. There is a clicking...
the most common is the control board.you may have to contact the manufacturer for a new board,my supplier does not have a replacement board listed
Jan 23, 2010 | Ovens
We used the self cleaning option on our Kenmore Gas Range (model number 665.72004101 or 665.75004101) and now the oven door remains locked and the error message on the screen is e1 - f5. How do we unlock...
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Open Questions:
Inner part of Triple element on 790.9912940 won't turn on I just experienced the same problem I've been reading about here and on other appliance repair sites: the inner element of my Kenmore Elite's front-right triple element will not turn on, despite the control panel saying it's "on." The range is about 2 years old, just like many other people have said. Also, Sears naturally wants to charge $65 to even come look at the part, and then several hundred more for a new element. From reading other comments and after talking to Sears, it seems like there is no extra warranty or recall on this part. This triple element is apparently a defective design if I can find so many reports of this exact same issue with only a cursory Google search. Would not have bought Kenmore anyway if it hadn't come with the house, because I've heard of this kind of thing with them far too often, despite their obvious good looks and nifty features... I'd rather not have to spend hundreds of dollars just to keep my $1.2k range working properly - for that price it should have a 5-year warranty at least in my opinion. I'm going to see about removing the element and putting in a new one on my own, as getting the part itself (Sears Direct Part Number 316216702) is only about double the cost of getting a technician to come out in the first place. You can see a handy part diagram of the range top at this link, by the way: http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0610001-00003.png The element that has failed on my range is part 15B in the diagram.
Sep 08, 2009 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 92002 / 92004 Kitchen Range Logo
172 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
