Question about Sony VAIO Digital Studio PCV-RZ24G PC Desktop
Hard Drive replacement
How do I replace the hard drive and re-install recovery disks?
The hard drive is inoperable.
  • towlam Nov 04, 2008
    I had my husbands friend replace the hard drive on my sony vaio pcv rz24g and he did not have the recovery disks. He installed Microsoft Office 2003 and a few other basic programs. When I tried to use my Sony Vaio Recovery Disks it says that it cannot read the disks? What can I do?
  • 149 Answers
Just open up the side pannel of the pc then find the hard drive unplug it from both cables the power and the data cable then put the new one in same as the old one came out *be sure to make sure the jumper is in the correct setting ex. single or master* then just start up the computer and put the restore cd into the cd drive and it should work fine after the setup is complete.
Posted on Oct 28, 2008
How do i install an operating system in a crashed hard disk drive?
if the hard drive is broken you can not - replace the drive. if the drive works as normal, then just use a windows installation disk or recovery disk.
Mar 12, 2011 | HP Computers & Internet
My Hard Drive is making strange noises when i start it, and my hard drive cannot be located. How can i resolve my problem.
Hard drive noises usually indicate a mechanical failure. Call dell and have them resolve the issue with a replacement drive.
Jan 02, 2011 | Dell Latitude D600 Notebook
Recovery Disc will not load OS on HD
laptop panasonic toughbook bios password pro
Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
UnmountBLE BOOT VOLUME
Generally and indication of a hard drive problem
Boot to the XP CD, go to recovery console (R at the 1st prompt), run hte command CHKDSK /R
If that fails to resolve, try a repair reinstall of Windows.
If that fails, replace the hard drive
Jan 07, 2010 | Dell Latitude D810 PC Notebook
The hard drive on my 4520 went down, and now I am having problems re-installing a windows system, and I have no recovery files, as the I realized that the recovery was on the hard drive that went down. Is...
if you have replaced the hard drive then you really don't need a recovery partition. if you are using the same hard drive you may need to replace it because of the fact that it is dead. if you have a new hard drive and can't get it to install windows it may not be the hard drive that is bad it may be the ide controller on the motherboard.
Nov 29, 2009 | Acer Aspire 4520-5582 Notebook
I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
May 12, 2009 | Gateway Profile 5 PC Desktop
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
Sony VAIO Digital Studio PCV-RZ24G PC Desktop Logo
202 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
