Jacuzzi J-315 convertible spa (110V hookup) won't heat.
I have a 2003 Jacuzzi J-315 convertible spa, hooked up to 110v, that will not heat the water. I got the spa used and before I bought it, it sat for the better part of a year without having any water in it, and without the filters in place. The temp sensor switch was just replaced by a very expensive tech, who told me everything else was working, but that I was going to need a new circulation pump, but it's working for now. The first time I used it, the heater got the water up to 104 quickly, but then it has dropped off down in the 80s (approaching ambient temp in southwest FL). Question 1: Can I remove the heater (plug the water lines) and troubleshoot it on a bench? Question 2: If it has debris inside the heater, will that shut it down? Question 3: If that is the case, can I flush it out and have it work? Thanks!
  • William D. Wiseman Feb 22, 2012
    I don't know how this wound up in Printers!!
  • William D. Wiseman Mar 22, 2012
    I replaced the heater and the tub heated up fine - for about two weeks. We turned the temp down from 102 last night to 97 for our grandkids to get in, and the heater wouldn't come on afterwards, New problem posted...
Nicolomd
  • 84 Answers
SOURCE: Debris in Gearing
check google for service-manual icq 475653626
Posted on Jan 04, 2008
pankaj_dic
  • 1250 Answers
SOURCE: 110v plugged to 220v
your adapter burnt out, its better you bougth a new one
Posted on Sep 29, 2008
SOURCE: MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
I had problems with my MCF 420CN in the past and I've found the best solution is to buy a new one from the Brother web store. The cost of a new machine is cheaper than buying a new set of ink cartridges. When the new machine arrives, I first use the cartridges from the broken machine and save the new ones as replacements for later use. Bottem line- new machine $49.99 versus cost of 4 ink cartrides $52
Posted on Nov 21, 2008
  • 142 Answers
SOURCE: canon pixma mp 780 gives wrong cartridge message and won't print
printer head is blocked......
great printer when they work.
Posted on Jan 28, 2009
PartsCenter
  • 125 Answers
SOURCE: low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Posted on Feb 26, 2009
What are the electrical requirements; 110V and/or 240V??
the voltage required is stamped on the plate on the electric motors
it will read
voltage
phase
current( watts)
duty cycle that plate tells you what the motor needs to run
Jun 23, 2016 | Jacuzzi Home
110V fan has been plugged in 220V power socket
You may be lucky enough that the capacitor exploded from the 220 volt charge. You will have to enquire at an appliance repair shop for exact advice. Basically I would junk it and get the correct unit for the voltage and cycles in you area.
May 17, 2013 | Dyson AM02 Tower Fan
Pool pump not pumping
A few things to look at-
  • Did you fill the pump pot with water?
  • Check to make sure that the pot lid o-ring is in place.
  • Verify that your plumbing is sound and has no suction leak.
  • Check water level in pool.
  • Make sure the voltage is correct. Many pumps come pre-wired for 220v. If you have 110v supplying the motor it will run at half speed. There is a diagram on the side of the motor showing how to convert to 110V. Make sure that your supply is 110v before converting the motor. If you switch the motor to run on 110v and hook it up to 220v it will ruin the motor instantly.
Feb 19, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
My dewalt drill is 3pin 110v I need to step up to 240v
You cant convert to 240 the plug you have is a 30 amp 115 volt
Nov 07, 2012 | Drills
Jacuzzi hot tub will not turn on found 2 burndt resisters having them replaced the owner before me was using 120 but it is a convertable unit so I had a 240 service installed what can I DO thankyou
Sounds like it has been wired incorrectly. DO NOT attempt to operate until you can properly determine the voltage and configuration. These spas have a conversion plug which must be swapped around to change the system properly. All 110V to 220V conversion systems ONLY convert the heater, NOT any other components, so make sure that the control circuit and pump(s) are still only getting 110V
Apr 05, 2010 | Pool & Spa
No heat in my jacuzzi echo z150 240 volt. i have 120 going to each terminal and with no power 13ohms across the terminals.
With alternating current 60 cycles means the power goes on and off 60 times in a second. With 220v one line is on when the other is off. With these oposing cycles you get 220v. If you have 110v to each but no 220v across them you are probally bleeding the power through the heater. you can check this by removing one of your leads from the heater then check them sepertly again. If this is the problem then you have a problem back further in your line. If you still have the problem of 110v on both it is time for an electriction. If you only have the 110v on one then you can check your breaker and be sure to shut both off and then turn them back on before you check them. I hope this helps, good luck.
Dec 06, 2009 | Pool & Spa
Wiring My Pool Pump
that pump is probably prewired for 220volts. you will have to check the diagram for how to configure it to 110v. most motor can be converted to 110v. If you are not comfortable with reconfiguring, contact a service tech.
Sep 13, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
Bought 2002 Cal Spa and the motor starts and stops repeatedly
It sounds like the motor is running to hot and cutting itself off as a safety. Make sure that the wiring is correct, and if it is you may need to replace the bearings (if the motor is running very loud or making a grinding sound). or you may just have to replace the motor.
It could also be a problem with the control panel. Do you hear the relay click on and off with the pump?
Check the voltage at the back of the motor with a voltmeter and make sure that it is 110vac and that it is there throughout the cycle.
Apr 01, 2009 | Jacuzzi Pool & Spa
k24674
jasbo
jasbo
