Question about Briggs & Stratton Garden
Ignition wire diagram for the mtd gt 1846 briggs and stratton
I need the wiring diagram for the ignition and coil
  • 246 Answers
SOURCE: mtd snowblower 4.5 no spark new coil,new plug
Hello pbck98:
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
>>If you have a New Coil/Ign Coil and Still No Spark, then
>>Turn the Coil Over and Check for Spark. Ign Coils are Wound 1 Way for Clockwise Engine and the Oposite Way for Counter Clockwise Rotation Engines. I have Seen Ign Coil Boxed Wrong and Turning the Ign Coil Over will Correct the Problem.
>>The Coil is Gapped to .015in from the Flywheel.
For Better Assistance;
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
  • 376 Answers
SOURCE: Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
Posted on Jun 10, 2009
lester482529
  • 226 Answers
SOURCE: I need the wiring diagram for a 7 terminal
GO TO PARTSTREE.COM. PUT IN YOUR MAKE AND MODEL# THIS WILL PROBABLY BE WHAT YOUR LOOKING FOR HOPE THIS HELPED
Posted on Jun 11, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
Wiring diagram
the wires you have are a ground wire a charging wire if you have a charger and the coil plug wire on a short blocked motor you might have a secondary stop wire to
Mar 23, 2013 | Briggs & Stratton Briggs Stratton...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Mtd riding lawn mower with B & S engine i need diagram of wiring harnes conections etc.
Most owner's manual have a wiring in them. I'll try to send you a my picture. See you later.
Dec 20, 2011 | Mtd Garden
Model H80-155003 engine magneto has no spark. Replaced coil, condenser & points. still no spark. Set points at top dead center of cam to .020. I need to check wiring, I have digital multimeter. I...
Check the ignition cutout which should short the coil to ground to stop engine, isn't operating while you are cranking engine.
To check grounding, measure resistance from chassis to non chassis side of points.
This should be very low (= resistance of coil primary) and reduce further when points close.
Feb 21, 2011 | Briggs & Stratton Ignition Kit 2-8 HP...
No spark and will not start
remove blower shroud off top of engine.Remove grass screen first.disconnect ignition kill wire from coils,retest for spark,if no spark check kill wire,wire that was disconnected from coils for short to ground.If wire checks ok,replace coils.Forty years in small engine repair.
Sep 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Wiring missing from harness to coil to card
here is a picture from the breakdown of a 15.5 hp briggs engine hope this helps e8059e1.jpg
Nov 19, 2009 | Mtd Garden
Where does the wire go off the points?
wire goes to the coil.condenser lead is attached to the same connection on the points.
Oct 01, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
'Get-Jet' Airplane mover
Hi Freddie ignition- to- flyweel gap means flyweel magnet positioned under the ignition coil armature.Remove the flyweel.Check the flyweel key(if it is sheared off install a new one).Remove the ignition coil.Clean the flyweel magnet and the ignition coil armature.Check the ignition coil wires and terminal to have continuity.Remove the breaker points cover,check the condenser and breaker points(they should not to be burned).The ignition breaker point gap and ignition-to-flyweel gap is 0.020" and the spark plug gap is 0.030". regards savumihai71
Nov 01, 2008 | Briggs & Stratton Electrical Supplies
Garden Logo
66 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
