Question about Acer Aopen MS698 Computer Speakers
My speaker are very low, can't ajust, and have a roar. coming from both speaker.
  • 62 Answers
Go to start, all programs, accessories, entertainment, and then volume control and make sure that the microphone is checked as muted. If you have a built in microphone then you might be getting feedback.
You can also adjust the main volume and wav volume there.
Posted on Aug 06, 2009
  • 34 Answers
adjust the sound effect, make the bass low.... if your using wmp, you can adjust this in the mixer or equalizer..... please rate my solution
Posted on Oct 28, 2008
What does it mean when you hear a recurring roaring noise coming from one of the rear side of a vehicle
jack up left rear and try to jiggle tire.if there is play could be wheel bearing.remove tire and check brake shoe/pad for wear.also check if exhaust is rubbing anywhere.bad rear speaker?lion hiding in backseat?lol
Feb 25, 2015 | Cars & Trucks
Roaring noise when braking - 2006 toyota sienna w/ 71,000 miles.
If roaring comes with trumbling in steering wheel, means you have problem with brake disk
if just noise with feeling of low brakingability: need to change brake pads
Oct 07, 2010 | 2002 Toyota Sequoia
Excessive running noise
yes there is. i take it that it is an oil fired pressure jet.
the fuel pump pressure needs to be set at 9 bar. run it for 10 mins and fit gas analizer to flue. ajust air to return 11% co2 and lock off you will find that the roaring has gone.. it needs a service by an oftec chap
Feb 03, 2010 | Kitchen Ranges
Roaring in deck and door speakers
bad rca's or bad ground on head unit .
Dec 23, 2009 | Car Audio & Video
I'm experiencing an audio distortion in my speakers when the sound is above 32. it sounds like a low roaring. how can i remedy this situation?
Check speakers or speakers ok just need replaced main board
Manufacturer Samsung Part Number BN94-00963E BOARD, MAIN ASSY
Sep 23, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
1974 super beetle roaring noise
make sure the axel nut on the drum is tight.it has to be very very tight. use a big johston bar
Jun 22, 2008 | Volkswagen Beetle Cars & Trucks
2001 LINCOLN CONTINENTAL ROAR WHEN ACCELERATING
Same problem with an LS...wheel bearings. Comes in the whole hub assembly. Just had it fixed for $340.
Jun 14, 2008 | 2001 Lincoln Continental
Speakers
HI Cassa
Happy Holidays!
Well, it sound like a bad cables connector, or dust in the IN connector on the sound card, you have to clean carefully with a special spray buy on Radio Shack or Comp-USA. it is for electrical parts (remember). or with a Qtip gently clean the inside connector. Another way is changing the cables for a gold plated connector if available. Good luck, if the sound roaring continue, may be is your power on the SUB of the speakers.
Nov 19, 2007 | Dell A215 Computer Speakers
Acer Aopen MS698 Computer Speakers Logo
167 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
