Question about Exercise & Fitness
I need a schematic manual for a weider super circuit master
225 lbs.
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I need a user manual for a Weider CJXT3 master
Go to this page this should be ithttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=WESY70092&version=0&company=11&modelName=WEIDER+CJXT3+MASTER+TRAINER+SYSTEM&language=
Posted on Apr 10, 2010
Testimonial: "Thanks that's great"
maxtreadmill
  • 832 Answers
SOURCE: Weider Crossbow Platinum
ADJUSTING THE RESISTANCE When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If a cable is pulled, the words RELEASE HANDLES AND READJUST RESISTANCE AS DESIRED may appear in the main display on the console.If this message is displayed repeatedly but no cable is being pulled, there may be too much tension on the Upper Cable . Adjust the tension as described below. To decrease the tension on the Upper Cable.turn the two 3/8” x 38mm Tension Screws twice,counterclockwise. Select the desired resistance setting.Repeat this step if necessary.CLEANING THE BAR GUIDES Over time, dust may build up on the Crossbar Guides , causing a squeaking noise as the resistance system is used. If this occurs, wipe off the Crossbar Guides with a damp cloth and a mild, non-abrasive detergent. Do not use solvents.
RECALIBRATING THE CONSOLE To recalibrate the Console , first plug in the resistance system . Plug the indicated end of the Transformer into the Back Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformerwhen using the resistance system., press and hold the NEXT button and the MOTORIZED WEIGHT ADJUSTMENT + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, then press the MOTORIZED WEIGHT ADJUSTMENT + button; this will start the recalibration process. This may take a few minutes as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120- volt outlet.The Console will be recalibrated. Use the resistance system as described in the CONSOLE
Posted on May 18, 2010
Where can i download or see user manual for Lic. NO NY0058580 Weider machine registry # CA-26230
I have the same exact question! I have a Weider Home Gym with the same information and cannot find any information anywhere! I'm in need of the user manual, too!
Dec 31, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
Weider multistation gym. Need manual.
Hi there, Well first thing you need to do is get a manual. Weider manuals are available on iconservice.com. To obtain the manual you will need the model number. This should be located under one of the seats. (usually the bench press seat) once you find the model number go to the web site listed above and go to the manuals section and input the model number. The manual is a free downlable and printable pdf file.
The manual will contain the cable routing info.
Good Luck! Tim
Dec 30, 2009 | Weider Nutrition Weider Total Body Works...
Need instuction manual for weider pro 3000 multigym
does anybody have english instructtions for weider pro3000 I need to reassemble HELP
Jun 01, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
May 19, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Have weider cross bow advantage home gym. need instruction manual
Here is a link the the manual in PDF for you.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/weider/manuals.d2w/report?man=&name=WESY39241&lan=
Sorry but I could not locate a source for the wall chart. The 2 places that used to sell them now say they are not available. Hope this helps!
Apr 06, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
Exercise & Fitness Logo
189 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
