We were getting an E20 error code, I replaced the pump but the machine keeps pausing straight after I start it. Now it is coming up with the E31 error code. I have tried to reset it by pressing Start/Skip/On together but still no joy. Any ideas?
how do I remove the spindle bearing from top loader fisher paykelI have the bowls apart just can't...
(More)
how do I remove the spindle bearing from top loader fisher paykelI have the bowls apart just can't see how to remove the bearing
lg dlg2522w gas dryer check filter flashing as soon as power is on. press start and the drum spins...
(More)
lg dlg2522w gas dryer check filter flashing as soon as power is on. press start and the drum spins but no heat. cannot manually change heat setting. gas is on and unrestricted, filter and exhaust checked, both are free of debris and clean to the outside.
I have cleaned the hole mashine - meaning: All pipes is deassembled and cleaned with high water...
(More)
I have cleaned the hole mashine - meaning: All pipes is deassembled and cleaned with high water pressure Both pumps are deassembled - cleaned and assembled again. No success - still E20 in connection with the program where the mashine has to let the water out in the middle of a selected wash. No matter what wash I select or different program. If I let the water out manually on the floor when it stays in the E20 error - it is possible to go on with the wash when selecting the start button again. This has been going on for 2 weeks now - very tired
