Question about Car Audio & Video
Jvc KD-R711 won't turn on
5 Suggested Answers
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Posted on Jan 24, 2009
lostinfamily
  • 149 Answers
SOURCE: trying to hook up a AMP
What I did to manualy turn on and off my amp is I put a wire hooked to the fuse followed by a switch and then from the switch ran it straight to the amp. Make sure that the wire plugged into the fuse is the on the fuse for the radio and that it is live only while key is turned on. I have this set up for police reason. They do not like loud music where I live. I have never had a problem with this set up. RADIO FUSE-------SWITCH----------------AMP
Posted on Mar 03, 2009
kenw392
  • 2226 Answers
SOURCE: I've installed my JVC KD-S17
Do you have power going to the red wire?
Posted on Jun 06, 2011
ynogami21
  • 670 Answers
SOURCE: Ever since I disconnected my car battery, my JVC
Please make sure to check the wirings and the fuse of the player. Don't forget to check the grounding of the player.
Please make sure that the wires are connected properly and that they are sending power to the unit. (it should only be able to handle 11v -16v allowance).
If the power and the fuse (plus the wiring looks good) you may need to check the faceplate because the components inside like small capacitors and IC's may have to be replaced.
**NOTE**
you may need to use a power tester to the said steps so you can check the continuity of the components.
Posted on Aug 08, 2011
JVC kd-r210 flashes and won't power up?
Sub
You need to look through the JVC KD-R210 manual.
A JVC Dealer / Installer may have seen a similar problem & suggest remedy.
Jul 14, 2014 | JVC Kd-r210 Car CD/ MP3 Player
How do i set the time on my car stereo it's a jvc kd-r200
Hold the SEL button to bring up the PSM menu, use up/down to select CLOCK H for hour or CLOCK M for minute, turn the knob to adjust, and press SEL to set.
Full details are on page 3 of the manual.
Mar 10, 2012 | JVC KD-R200 Car CD/ MP3 Player
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Need radio code for jvc kd-r711
Hi :) This is a site that has programs to fine code by putting in the serial number of the radio. You can download them and use them free of charge and there is all kinds of info on allkinds of Radio.
http://car-radio-unlock.blogspot.com/search/label/Radio%20code%20calculators
May 28, 2011 | Car Audio & Video
How do i permanently keep demo mode off on my JVC car cd player? Everytime I remove the fascia it resets the settings and the demo mode comes back on. The model I have is the KD-R711. Thanks
Hold down the menu button for about 2 seconds.
Will take you to menu mode, first option should be demo, if not scroll over to demo menu
by using the know. Push the knob in to enter the mode, then using the knob get to off display, push the know in once again to set it to off. After hit the menu button to get out of menu mode.
Jan 08, 2011 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
175 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
