Universal a/c control system
I,m trying to fit a universal pcb to an a/c split unit but cant figure out which wires to use for the speed settings on the internals fan.there are 6 wires Black=n, white & red to relay red =L, Grey,yellow and brown.
If I connect the red to any of the speed relays on the pcb it works but only on that speed. There is no pcb terminal for the Red L only for the speeds.
any help would be appreciated.
  • wannawagon Feb 20, 2009
    SAME PROBLEM (FUJITSU SPLIT) are the rede whit and black wires mains voltage, and the control board bridges one or two of them, i phoned fujitsu and they told me that they were low 12v DC which didnt make sense. assume the white yello and black are mains voltage in (with condensor)
    HOPE SOMEONE CAN HELP - EVEN IF THEY CAN CONFIRM THAT THE RED WHIT BLACK ARE MAIN VOLTAGE IT WOULD BE GREAT
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 588 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: "i'm replacing my Rheem RBGC
There should be a wiring diagram on the side of the new motor.
The brown and the brown w/ white go to the new capacitor you should have bought with the motor.
The black and white go to your L1 & L2 power source. The remaining wires must be capped off.
Posted on Feb 25, 2010
Testimonial: "Thanks for the info. although a day late it confirmed what a friend had told me also. Didn't see any wiring diagram on the new motor."
GodBlessU
  • 3513 Answers
SOURCE: Internal Blue wire from "W"
Please check the bellow links to see the wiring diagram :-
http://www.tpub.com/content/photoprint/TM-10-3610-203-14/css/TM-10-3610-203-14_20.htm
http://www.pdfee.com/search/Air+conditioner+wiring+diagram
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 28, 2010
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
GE split air unit.remote is intermittent.I have 2 remotes same problem. Should I replace the display board or the pc board it plugs into?Which one controls the signal?
Replace new batteries and check. Switch off ac,remove any dc wire from indoor unit and then re-fix it.Now try. If still problem, repair/replace PCB
Jun 01, 2011 | GE Quiet-Aire Ductless Mini Split System...
Nec split system air con will not respond to remote control.
Remove batteries and replace with new batteries and restart. If still problem, unplug DC wire to indoor display sensor and plug it after a minute. Now try with your remote. If still problem, try with another remote. If no result, PCB receiving sensor defective. Replace display sensor or PCB
Jan 27, 2011 | Heating & Cooling
I have a bondaire ULB 18HP mini Split Air Conditioner and need a remote control. Are you aware of: How I can get a remote Is there a universal remote that will work What are the remote codes for this unit...
I purchased a universal remote CHUNGHOP K-1028E on ebay for this unit but the bad news is it only does basic functions and its in Celius.
Functions that work
On/off
heat
cool
wind/fan speed
mode
Led light
3 flap settings
code is 348 and 453
I also have a harmony one remote and tried learning the original remote functions but doesn't really work properly
GOOD LUCK
Jun 06, 2010 | Heating & Cooling
IMAGERUNNER 2000 SYSTEM E100
This can be caused by the following....
*When the laser scanner motor is started up, the BD input signal does not arrive within a specific period of time.
*When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
*During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause:
  • The wiring is faulty (short circuit, open circuit).
  • The laser scanner unit is faulty.
  • The DC controller PCB is faulty.
  • The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Apr 15, 2010 | Canon imageRUNNER 2000 Copier
Universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
Feb 12, 2009 | JVC TH-G30 Theater System
Heating & Cooling Logo
596 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
