Unable to connect printer/scanner to computer
Sir I dt Install my scaner
Posted on Oct 28, 2008
Laserjet m1136 mfp
Have you considered installing the scan tools on the other computers? Print sharing is a function of windows; assuming that the printer is not a true network printer. Windows does not have the ability to share scanners. But this is where the software can scan the network and find a HP scanner. Also some scanners can perform a "scan-to" function; but I believe the software need to be installed on the destination computers for this to work as well.
Dec 11, 2013 | Office Equipment & Supplies
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
The printer was unable to communicate with your computer please powercycle the printer check the connection and try again
Please check your control panel and make your current printer as default printer. Check also its driver on your computer for malfunction. Re install the driver if needed.
May 06, 2011 | Computers & Internet
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Scanner failure unable to scan, copy, or send a fax
Hi and thank you for using fixya:
I would recommend trying one of the followings:
1- install a fresh copy of your printer/scanner drivers.
2- check your firewall program it might be restricting the scanner software .
3- check the connection between the scanner and the computer
Good luck
Mar 20, 2010 | HP OfficeJet J4580 All-In-One Laser...
Hp psc 1402 all in one scanner not scanning
just chek in my computer is that show any scanner last on screen if it is then scan thru that tool if there is no scanner icon avalable then i need to set drvier thru device manager... it's help u
Jan 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Scanner not working..
This is what HP has to say about unable to scan
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00803473&lc=en&dlc=en&cc=us&product=441125&rule=662&lang=en
if this doesn't fix the problem, you have to uninstall adn reinstall the software.
Note: install the printer software on the computer first, then connect the printer to the computer.
Nov 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanner won't scan
try connecting it to another computer. If it works, then it is a prblem with your computer, otherwise it is with your scanner hardware.
If you can open the scanner clean the circuit board with (Isopropyl alcohol) IPA solution. you can also try replacing the ribbon type cables connecting the print head.
If the problem arised due to dust accumulation, the above action should solve the problem.
Jan 14, 2007 | HP PSC 2355 All-In-One InkJet Printer
Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Nov 27, 2006 | HP PSC 1510 All-In-One InkJet Printer
482 people viewed this question
k24674
jasbo
jasbo
