Question about Toshiba DKT 3010 Corded Phone
How do i turn off call forwarding on toshiba DKT 3010 sd
My phone says call forward external. How do I get out of this mode?
3 Suggested Answers
  • 13 Answers
SOURCE: DKT 3010 SD programming mode?
If the phone is on any Toshiba DK system, enter programming mode my pressing the following sequence (without selecting an intercom line, or an outside line, but at the phone's idle state with the handset down) *#*#1*2*3
On a CIX or CTX System, again, at the phone's idle state w/ handset down dial *#*#1*2*3*
Posted on Mar 26, 2010
  • 225 Answers
SOURCE: How do I forward my
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Posted on Dec 08, 2010
How do i change time on toshiba DKT 3020SD
Download manual from here: http://www.manualslib.com/download/375822/Toshiba-Dkt3010-Sd-Digital-Phone.html
Mar 09, 2015 | Toshiba DKT 3010 Corded Phone
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
Mar 12, 2014 | Toshiba Strata DKT-2010-SD Digital Display...
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
TOSHIBA MODEL DK3210-SD we forwarded calls during lunch and now can not get them to disconnect..even using the codes provided
you probably could have a nite button on your telephone. Depending on the type of forwarding you set ( there are over 5 different types) you have to select the right one to turn it off. Go to http://www.telecom.toshiba.com/ and view the users guide
Aug 06, 2013 | Toshiba DKT-2020 Corded Phone
Jan 07, 2010 | Toshiba DKT3020SD Corded Phone
I have DKT-2010SD toshiba business phone. how can i do a call forwarding for after hours?
There is a couple of way to do this. If you are trying to call forward the lines to a outside extension you will have to press Intercom #6011 9 (your phone number you want it to go to) then redial. Your second option is to get call forwarding through your telephone provider. Usually this is a low cost addition and is the way I would forward calls externally. Hope this helps.
Oct 27, 2009 | Toshiba DKT-2020-SD telephone
All of my external calls go straight to VM!
sounds like you are call forwarded. But to know this you should plug in a phone that has a display. Also it depends on your system, being a 3XXX series phone you most likely have a CTX and the call forwarding codes can be found here
http://guides.idacomusa.com/
Sep 18, 2009 | Toshiba DKT 3010 Corded Phone
Forward call
hit intercom #6041, 9, and you number, hold, speaker.
Apr 09, 2008 | Toshiba DKT 3010 Corded Phone
Volume for External Call Forwarding
you need to work on the padding tables inside the system, you will have to know the programming or aquire programming software if it is a ctx or above
Oct 19, 2007 | Toshiba DKT 3010 Corded Phone
Call Forwarding (External)
The manual for this phone can be found here http://its.auc.ca/docs/phone/CTX_Complete_Digital_Telephone_User_Guide.pdf
I had the same problem with our phone, the problem may be the administrator of the phone system needs to give you call forwarding rights on your phone. if you do not have these right the manual does you no good. call forwarding starts on page 30
Oct 18, 2007 | Toshiba DKT 3010 Corded Phone
Toshiba DKT 3010 Corded Phone Logo
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
