Question about Motorola Mobility W375 Cellular Phone
No ringer volume or speaker phone.
Phone will not ring with speaker volume set to high or any other level. Vibrate is turned off. Speaker phone will not work either. Keypad volume works and earpiece works. When I select a tone and hit play, I get nothing. Did not get wet or anything. Is there a setting or a manner mode I'm missing?
  • irismaeder Oct 29, 2008
    Similar problem, no ringing even though all settings are OK. Any idea how to solve.
    Similar post here already:
    https://www.fixya.com/support/t629669-w3...
    But also no solution.
  • vincent2668 Nov 03, 2008
    Solved my problem by powering off phone. Plugging it into charger. Then turing power on while plugged into wall charger. Everything worked after that.
Posted on Nov 02, 2008
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Somehow the ringer got turned off. Can't figure
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
My LG220C ringer volume starts at about 0 and slowly increases in volume as you wait. With the Speaker "on" it starts with a loud ring. What needs to be changed to start the ringer volume at my high...
i BELIEVE there is a setting I think in either your ringer volume or in your sounds or tones (sorry I cant be more specific but its been a ling time since I had a phone that even came with that option) that will give an option of ascending ring which it sounds like to me it is set to this you need to change that
Oct 18, 2010 | LG Cell Phones
I can't hear any sound.And instead of ringing it vibrate.Even I've try to listen song but nothing is happening.
Hi there
First go to your ringer settings to check if the volume is not too low or turned off.
The problem is from your RINGER/SPEAKER,
The ringer/speaker is what brings out sound from your mobile phone when you are called,you receive a text message or you are playing music.
The ringer of your phone is faulty and you need to get a repairer to replace it for you to solve this problem
Thank you for visiting fixya
Feb 25, 2010 | Sony Ericsson K800i Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
RAZR ringer (speaker) doesn't work
the speaker inside the phone is in mis contact or it is dead .. try changing the new speakers into it ... it will work ...
if u are not gud at servicing then visit the technician........
Feb 11, 2008 | Motorola Mobility RAZR V3
Motorola Mobility W375 Cellular Phone Logo
429 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
