Question about Philips 170B4BG 17 in. Flat Panel LCD Monitor
Green screen problem
Everything has gone into shades of green on my monitor. in addition the menus and adjustments buttons just result in a few words of chinese which i can only assume translates as " its broken". Red channel appears to still work as the menu box has a red header. have tried reinstalling drivers with no success as xp wont let me. reinstalled graphics card just in case with no change. computer working fine on another monitor so i am a bit stumped! any help / suggestions would be greatly apprieciated
  • Gene May 25, 2017
    Hi iain mitchell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the name and model number of your monitor.
I just had a new hard drive installed and the business is closed today. I can not see the entire screen on the desk top and on all screens from the internet. How do I fix the monitor so I can see...
On the monitor is a button that looks like two arrows bending to wrap to each other. Press that button. That's the Auto Adjustment button. If that doesn't do it, push the menu button and work through the menus until you find where to adjust the size and position of the screen.
Jun 25, 2011 | HP 2009M Monitor
I purchased my Acer monitor only a few months ago. I opened a very large file (pdf) of artwork for new label design......it hung up my computer due to the large size. However since then my monitor is a...
When you start your computer, if before Windows starts up it's a shade of green, it could be as a result of the screen cable not plugged in properly at some point. If not or if that doesn't work, it could be the software or hardware but I don't know how a pdf can do that??
Feb 04, 2011 | Acer 22" X223w LCD Monitor
TV images have gone green
power might be to low for it
Apr 16, 2010 | Toshiba 32HFX71 32" TV
Everything's Gone Green !!!
Try it in someone else's computer.
To see if it is the Monitor or the Video card...
Jul 07, 2009 | LG Flatron L1750S 17" LCD Monitor
Broken monitor screen, model IIM15J
it is called colour fade.it can be seen in many old and few in new crt monitor.Due to the not properly fitting inner parts of board and other. it can be repair expert technician by soilding.. it is not softwere problem..--thanks
Jun 15, 2009 | Computers & Internet
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then...
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
May 08, 2009 | AOpen F2715-8S Monitor
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Philips 170B4BG 17 in. Flat Panel LCD Monitor Logo
27 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
