Question about Tamron Telephoto SP AF 90mm f/2.8 Macro Autofocus Lens for Pentax AF
TAMRON A272 USER MANUAL
Where can I find a Tamron Fotovix repair manual
Repair manuals can be bought by certified repair centres. Sometimes you get the manuals when you have done the repair course at the firm. Not sure Tamron does so. But they most of the time don't sell these manuals to normal people, to avoid they start opening a lens, because they never will be able to put it together as a working lens, without the tools, like a collimator.
Jul 12, 2014 | Tamron Cameras
Tamron service manual
See if this site is of any help
http://camera.manualsonline.com/manuals/mfg/tamron/tamron_camera_lens_product_list.html
Jul 02, 2014 | Tamron 70-200mm f/2.8 Di LD IF Macro AF...
User manual
Try this website out and let me know ! http://www.retrevo.com/samples/Digital-Camera-manuals.html
Mar 07, 2014 | Tamron F AF TELE-CONVERTER 2X C-AF1 BBAR...
User Manual
I checked the Tamron website menu of manuals and one is not listed. This is a pass-thru device, so other than placing it between your lens and camera body, there should be no additional settings. Your camera focus and exposure is thru the lens so the camera should adjust seemlessly. Please tell us what the problem is, what lenses and body you are using.
Mar 07, 2014 | Tamron F Af Tele-converter 2x C-af1 Bbar...
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
I need a manual for Tamron Camera Lens 28-200/3.8-5.6
You didn't supply what kind of Tamron lens it is. I'm gonna go ahead and give it my best shot on a guess: Tamron 28-75mm f/2.8 XR Di LD Aspherical (IF).
If I'm correct, you can download the manual here: http://www.tamron.com/assets/pdfs/A09.pdf
Hope this helps!
/Chris
Jan 17, 2009 | Cameras
Tamron 28-200 AF Aspherical LD. Does it have manual focus? If yes, where?
There should be a switch just in front of the back of the lens marked "AF" and "M". Set it to M for manual focus, AF for autofocus.
Aug 30, 2008 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Will not autofocus
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Tamron 28-200mm f/3.8-5.6 Super II Macro...
Tamron Telephoto SP AF 90mm f/2.8 Macro Autofocus Lens for Pentax AF Logo
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
