Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Belt not turning
Turned on the vac and the belt is not turning. It is tight on the roller, so it doesn't seem to be broken.
thanx,
  • leazels Feb 11, 2009
    My model has brush control and when this is on the belt wont turn and it makes a really loud noise.
    The belt is tight so ipresume is intact and doesnt appear to be twisted.
  • 372 Answers
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Posted on Oct 28, 2008
Why doesn't the brush roller rotate?
Hi, this is Jim with Crucial Vacuum,
The belt may not be broken, but it may be lacking in tension and therefore unable to rotate the brush roll on its own. You're going to want to replace your vacuums belt every 3 to 6 months depending on usage. Check to see if the belt is loose, or over stretched.
Check the brush roll as well and be sure its securely locked into place. It could be slightly loose causing a lack of communication between itself and the belt. Our video can help with fitting the belt in properly with the brush roll:
https://www.youtube.com/watch?v=LRV8280PQxc
You can purchase replacement belts and brush rolls for your Hoover Linx directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-linx-platinum-roller-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 05, 2015 | Hoover Platinum LiNX Cordless Stick Vacuum
The panasonic EComax light rollers not turning , belt is fine. filters are fine.. and even with power on nothing happens. switch is on carpet mode.
"belt is fine" . Not likely. Belts need replacing yearly. Just because it isn't broken doesn't mean it's working properly. Most vacs should be serviced annually. Take it to your local vac shop for service.
Oct 26, 2014 | Vacuums
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
There is power but the motor seems to not turn, therefore, there is no movement via the rollers. please help
The belt which turns the roller brush is probably worn and therefore not turning the roller brush. You can get a replacement here:
Filter Queen Majestic Replacement Belt
Nov 05, 2009 | Filter Queen Majestic Canister Vacuum
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
New noise when vac is run
mine was allowing the roller/beater bar to hit the cover as it turned take the cover back off and ensure the beater is in the right place then that the cover is locked in the right place then you can spin it by hand (power cord unplugged of course) and make sure it is clearing everything. BTW, the belt has to be stretched to get the beater bar in place like on most vac.s
Jan 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Bagless Windtunnel Vacuum roller does not turn.
you have a broken belt. look on bottom of vac remove screws until cover comes of. you will find broken belt inside. take that with you to get a replacement
Nov 19, 2008 | Vacuums
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Kirby Vaccuum Cleaner:
likely a broken belt. turn vac over and see if roller turns free. if it does the belt is broken. turn the handle on front of vac. turn latch under headlight and remove head. open bottom plate and return handle to normal position. belt and brush roll will lift out. reverse procedure to install. directions are usually printed on the head of vac under headlight.
J
Jun 12, 2008 | Kirby Vacuums
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
210 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
