Question about Samsung SyncMaster 940N Flat panel Monitor
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
  • Samsung Master
  • 1,684 Answers
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 26, 2012
Starworx
  • 4 Answers
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Posted on Dec 17, 2009
tantong
  • 138 Answers
SOURCE: Samsung Syncmaster 940n - white screen
I don't think the driver is a problem. This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 19 Answers
SOURCE: my samsung syncmaster 940n is no longer working,
it mite not a problem from the monitor, try and check your data receiver cable either from a computer system with another monitor.
If the response is different i.e not displaying... its a hardware problem... a vendor can check it for you
Posted on Oct 07, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 940n monitor that turns on then goes black
rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
  • 65 Answers
SOURCE: SyncMaster 940N - screen has gone dark when turned on...
Sounds like the backlight has failed. The backlight illuminates the liquid crystal display. Without it, everything's black. Though, as you observed, if you get really close you can still see something of the image.
Posted on Apr 16, 2010
Aspire AX1200-U1510A starts but monitor doesn't show anything. Monitor works with an odl Dell.
If an old Dell monitor works with your computer then that monitor has something wrong with it.
Try to plug in the monitor to a wall outlet but do not plug it to your computer. If it still doesn't show anything, then you should replace it. You can contact the manufacturer of the monitor. You might have a warranty for it. They might fix it or replace it with a new one.
I hope this helps.
Carlo
Nov 20, 2012 | Acer Aspire X1200U1510A PC Desktop
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
Not enough data in computer for emissions testing
Has the battery been disconnected, or has it gone dead? Every time the battery is disconnected, all trouble codes are cleared, the check engine light is turned off, and all system monitors are reset. For the monitors to get back to a 'ready' status, the vehicle needs to go through one or more (sometimes quite a few) drive cycles.
When you go to the emission station, they check for codes, AND also check to see how many of your monitors are in a 'ready' status. (This keeps people from disconnecting the battery, and thus clearing any trouble codes, in order to pass emission tests).
If you have not disconnected your battery for a while, but the monitors are still not showing 'ready', you need to have a qualified shop check out your computer and other electronic systems.
Aug 30, 2017 | 2001 Chevrolet S-10
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
For the past few weeks my Hanns G 19 inch LCD monitor keeps having troubles displaying a screen. It constantly makes a loud sound that it repeats and it takes several hours before the green light appears...
From the description you give, this sounds like a failure in the circuit board, normally the capacitors go and the thing refuses to power up, however, the fact it defaulted to a low resolution indicates that the actual board is in some way failing, possibly a damaged circuit, or component.
I would think it could be repaired and it may be a simple job for someone who can identify the failing component, however, I think that the cost of getting it repaired would outweigh the cost of replacement
Jun 22, 2011 | Hanns.G Corporation Computers & Internet
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
Samsung SyncMaster 940N Flat panel Monitor Logo
611 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
