Zennox record player USB and aux plugs, the record player keeps stopping and returning the needle to the side and stops playing literally 30seconds into the record, doesn't matter what track it's on it only lasts 30 seconds and then returns to the side automatically and stops spinning? I realise some of there record players recognize when the record has ended and auto return the handle to the side, but this is doing this half way through a track
5 Suggested Answers
  • 42 Answers
SOURCE: Record will not play to end.
There is a mechanism underneath the deck which senses "end of record". This is operating too early and will require adjustment.
Posted on Jan 25, 2009
Grubhead
  • 5259 Answers
SOURCE: I have an older 78 record, and the arm
There should be some kind of screw on the arm to adjust it. You might have to experiment, or get a service manual. When adjusting, try doing it without the platter powered, by hand movement only.
Posted on Nov 30, 2009
SOURCE: my prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Posted on Jan 08, 2011
STYLUSCITY
  • 271 Answers
SOURCE: how do I adjust the auto return on a JVC A-21
Hi, this problem is caused by the cut off switch not depressing far enough to turn unit off. To remedy you need to do as follows.
1. Disconnect from power supply.
2. remove platter.
3. Flip unit over to expose the underside and remove all screws.
4. Remove base board.
5. Look at the gearing beneath the tonearm and identify switch that tonearm depresses at the rest point.
6. Loosen switch retaining screw and turn switch toward centre of turntable slightly until it clicks or closes. Tighten screw to hold switch firmly in place at that point.7. Reassemble and test.
Good luck. John. Styluscity@gmail.com.
Posted on Nov 03, 2011
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
I have a BOSS BV9970 stereo. the usb will not let me play my ipod, it starts to load it but stops halfway through. and when i try to use the aux, my right rear and right front speakers will not play.
sounds like a loose connection on the aux input. boss has a pretty bad reputation for there usb / aux connections inside the unit. also if your right rear and right dont play on anything its bc you have them turned down. or if this is recently installed they got mixed up. please let me know more details so i can better help you
Mar 20, 2011 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
I have a zennox tape to digital converter manual
I bought one as an offer from Scotland on Sunday and it came with a CD and a mini pamphlete neither of which had instructions - advertised as plug and play.......my a**e
Feb 21, 2010 | Audio Players & Recorders
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
55 people viewed this question
 Grubhead
Grubhead
