Hisense TV mod #LTDN46V86US. The power light blinks 3 times and it does not power up.
When turned on the power light blinks 3 times and won't power up.
  • 2600 Answers
SOURCE: Where do I obtain a Hisense TV Service Manual for
Below the link for your Tv please download
http://www.hisense-usa.com/applications/documentlibrarymanager/inc_documentlibrarymanager.asp
Thanks
Tony
Posted on Dec 08, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Hi, I own a 50 inch
Hi erron_d,
The 6 blinks ended with 3 blinks error code is a general IIC bus error detected upon self test of the processor. This is located in the main board which is the affected parts is the system IC and or some of the resistor in line with this IC going to EEPROM IC. This is responsible for powering on the unit. If not isolated the symptoms will remain the same. I would advice you to look for a qualified technician or send the unit to your local Philips Service Center because diagnosing the fault required some test instruments and skills in that kind of symptoms. Your power supply board is not an issue here.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 19, 2011
caroldon
  • 17130 Answers
SOURCE: tv power light blinks and
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on May 28, 2011
  • 8457 Answers
SOURCE: TV won't show picture the
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Posted on Jul 30, 2011
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
The power light blinks 7 times, pauses, then blinks 3 times. Sound but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 28, 2014 | Hisense Televison & Video
No picture hisense flat screen LCD tv
Sounds like a main board fault. Contact any service technician to make it confirm. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Hisense Brand TV REMOTE EN-31201A for...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Can't change the aspect ration from wide to normal on my hisense tv ltdn46v86us
You might have to enter its service mode options to adjust this fault. Actually entering in to service mode, and making data adjustments with it, is really a skilled work. Anyway, visit this site named'Electro-help'. Entering into service mode proceedings to many brand TVs are described in detail. Check it and determine whether you can do it by yourself or not. If you are not sure, do not get in to this mode, and make any adjustments there. Check this link, and select the site named above. Pull up older posts there.
Jul 26, 2012 | Hisense Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
My 42' hisense tv turns on then blinks. blue then
Take it to a servicer with proof of purchase or back to the store. You will get it repaired for free or get a new TV.
Apr 19, 2012 | Televison & Video
Hisense ltdn46v86us
examine power supply carefully looking for bad caps as seen in this photo with tops puffed up.
Apr 02, 2012 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
772 people viewed this question
Top Televison & Video Experts
