Question about Laser HL-5340D Mono 30ppm 1200x1200dpi 16mb With Duplex - BROTHER - HL53 Photo Printer
How to reset the fuser life - Laser HL-5340D Mono 30ppm 1200x1200dpi 16mb With Duplex - BROTHER - HL53 Photo Printer
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
Help me with reset fuser problem on Brother HL-5270DN
HelloTo reset fuser on your HL-5270DN you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu. Then you will go for fuser reset.
Plz sure the fuser must be OK/replaced before applying this action
Good luck
Do rate the solution if got help
Dec 06, 2010 | Brother HL-5270DN Laser Printer
Fuser life on screen please advise
When Fuser Life message on the screen of your Lexmark X502n printer is displayed, replace the fuser immediately, For your reference, check this article in the Lexmark website. Just click on this link: http://bit.ly/b4lggj . There are also links on that page on replacing the fuser and resetting the fuser page count. Hope this helps.
Apr 15, 2010 | Lexmark X502N All-In-One Laser Printer
How do you reset the fuser count of a Brother HL4070CDW?
If reset parts is life not available after OK > Machine Info > Reset Parts Life (if it only shows "Parts Life", then do this:
Press GO and UP arrow at SAME TIME > Reset parts life
Scroll up or down to choose which part to reset
Press OK and confirm
Apr 14, 2010 | Brother HL-4070CDW Printer
How do i reset fuser kit for brother DCP 9040 CN
Press 3 and 9 at the same time. This gets you to a hidden counter reset menu. Brother support was not able to give me this information said I had to take the printer to a service shop. Fortunately, one of the shops told me this information. Ooooo. Big secret. What B.S. !!!
Apr 07, 2010 | Brother MFC-8460N Laser Printer
How do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Mar 25, 2010 | Brother HL-4040CN Laser Printer
Brother HL-5170 fuser reset
should be a service selection in the user tools/ menu. reset life/consumables/replacement etc.
Aug 04, 2009 | Brother HL 5170DN Laser Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
Oct 13, 2008 | Xerox Phaser 4500 Printer
Laser HL-5340D  Mono 30ppm 1200x1200dpi 16mb With Duplex - BROTHER - HL53 Photo Printer Logo
162 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
