Question about Nintendo Wii Console
Handsets not responding.The lights light up at first & then go out.Options appear on screen. Have tried new batteries & checked the black receiving bar is working (on a friends system). Has the syncro
Handsets not responding.The lights light up at first & then go out.Options appear on screen. No picture of a hand. Have tried new batteries & checked the black receiving bar is working (on a friends system). Has the syncronisation been lost? Cheers,Heather x
  • heather333 Oct 29, 2008
    Thankyou VERY MUCH! Its Fixed thanks to you!! :-) x
    Novelist:
  • 111 Answers
Hi there heather.
it seems that your synchronisation could have been lost, bear in mind some Wireless connections such as that of the wii can be scrambled/lose single if there are alot of electrical appliances in close proximity, as this messes with the wireless signals being transmitted.
you may just need to Re-Sync your Wiimotes which is simple. on the underside of the mote, inside the battery compartment there is a small red Button, pressing this whilst pressing the sync button on your nintendo wii should successfully sync each mote to your wii allowing you to play :)
hope this helps
Posted on Oct 28, 2008
Engenius handsets won't respond
Will likly cost more to repair that replace. Sorry, that is the way our society is today....throw away what dosen't work.
Jul 27, 2014 | EnGenius DuraFon 1X Handset DuraFon 1X-HC
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
My android 3g T-mobile phone has a blue light on top and won't turn on even when hooked up to desktop with USB. help!!
you need to do a hard button reset and this will fix your issue 100%!!! i found the info at tmobile.com/forums.
myTouch: How to Hard Button Reset Options
01-11-2010 10:59 AM
If the handset is locked, frozen, or unresponsive, you can perform a master reset it using the hardware keys instead of the menu. A master reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). To perform a master reset using hardware keys, follow these steps:
1. If the device is responding at all, back up your data before proceeding.
Note: The device must be turned on to synchronize or transfer files.
2. Turn off the device.
Note: If the device is unresponsive and does not turn off, remove and then reinsert the battery.
3. Press and hold the Home key and the Power key for at least 25 seconds, even if the Startup screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Press the Home key and the Power key again.
6. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
7. Once the device finished the data wipe, select reboot system now.
Dec 24, 2010 | Cell Phones
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi My cordless phone does not receive or make calls anymore. I have checked and everything seems to be working OK. There is a small icon that appeared on the screen ,like a battery,, and is all black
The battery indicator on the handset tends to be misleading. You may need to replace the battery, or if the phone is under a year old, try charging over night. Simply unplug from the phone jack, leaving base plugged into power.
Apr 18, 2009 | Lands Phones
Base won't charge handset
the base of your handset needs to be repair take it to a tech
Apr 04, 2007 | GE 26938GE1 Cordless Phone
BT Synergy 2150 Cordless Phone
As far as I can understand your problem, there is nothing wrong, just view the new calls ( options/caller id/options/view/ up and down arrows to scroll through caller id's). New calls message will then disappear, although it doesn't really matter if you don't do any of this.
Apr 13, 2007 | British Telecom Synergy 2110 Cordless...
Nintendo Wii Console Logo
95 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
