Question about Neovo F-417 17" LCD Monitor
Menu screen appears all the time, flashes through different categories
The monitor i have is a Neovo F-417 17" LCD Monitor and i have had it for over 6 months. I have had no problems with it previously until now. Yesterday it was all fine. This morning when i turn the computer and monitor on, the menu screen from the lcd monitor appears all the time and automatically flashes though each of the categories such as contrast, brightness, auto adjustment..... I have tried pressing all the menu buttons but this has not helped. I also have restarted my computer many times and have unplugged and replugged power chords and chords connecting to the monitor to the computer. I have also run a virus check. I don't know what else to try. Please could you try and tell me what the problem is. Thanks
  • 1 more comment
  • Anonymous Dec 13, 2007
    I have almost the same problem. The strange behavior starts after about 30-60 minutes of use. I've tried to clean the plate.
    Looking forward to improvement, Peter
  • stellinapazz Oct 27, 2008
    sono 2 giorni ke lo scherma del pc lampeggia prima con colori piu forti e poi chiari e appare la scritta auto adjustament e p'oi auto finished...ho provato di tutto ma il problema ce ancora. potete aiutarmi? grazie
  • Anonymous Jan 23, 2009
    I also got same problem with "Auto Adjust" pop-up window in the middle of the screen. It seems, it is realy moisture problem. My daughter put her toy with water absorbed inside for 3 days near monitor and in the distance 8-10cm from monitor buttons. After 3 days this toy left dry, but monitor cant be switched ON. I have reassemblied monitor and dried buttons board by hair fan. Trouble disappeared. Now I testing NEOVO monitor before I put cover back.
I tried cleaning the plate as suggested but had the same problem. So I decided to see what would happen if I disconnected the button board all together. I haven't had a problem since. I don't know if this is a good idea or not but it worked for me. You need to make sure the monitor is in the on position before you do so. Since obviously you can't turn it on or make adjustments to the monitor afterwards but I never made any adjustments to it anyway.
Posted on Feb 01, 2008
  • rudvorak Oct 05, 2010
    Oxidation of cold joints causes this problem with screen menu. It appears sooner or later, it depends on the surroundings the screen is set in.
    You need to unscrew all the 6 screws to open this monitor, 4 in its corners, and the remaining 2 fixing monitor to weighty stand. Then you can dilate monitor on its sides, top and bottom, starting in its corners, using considerable force and a flat screwdriver.
    Clean joints with any soft emery paper, eventually make conservation of them.
  • endabrignull Mar 24, 2011
    You don't even need to take the whole back panel off. You simply unscrew the three screws holding on the small board with the buttons on and turn it round and disconnect the wires.
Had the same problem on several occasions. The problem seams to apear after a period of several days of inactivity in a cold room, so I think it has something to do with moisture. The problem was solved after gently warming up the region of the buttons with a hairdryer.
Posted on Sep 06, 2007
Another solution from me:)
Got small magnet on LCD control buttons and touch it with all buttons and Suprisee:)
The problem is solved...
Posted on Dec 17, 2009
Same problem with me, i opened it up, unscrewed the board looked at it a bit, couldn't see anything obviously wrong, put it back together, and the problem was gone! very strange!
Posted on May 17, 2008
My monitor is doing the exact same, i will try these tips to see if they work other than that smash it up hehe.
Posted on Dec 20, 2007
    New Friend:
Hello, this model is a piece of funny electronics :-) , I ve got this for repair ( PSU was ko ) and this was a second fault ( auto adjusting windows appears all the time ) I have measured the microswitch for auto adjustment and it looks that had sometimes a drop about 600mV on diode test when should be off, I have replaced the uSW but start to appear OSD and menu rotated on the left :-D so I have replaced the uSW for the left arrow and all is ok ( to be honest after this I have replaced all uSW because the price is few cents and I don't intend to open this LCD again :-) )
Posted on Aug 11, 2014
Same for me just cleaning the pin en resold "led power"
Posted on Jan 22, 2012
The problem is the little electronic plate or circuit (sorry if my english is not that good)that has the buttons on it to control the functions on/off, left/right, up/down and auto adjust. I have had the same problem and solved it. You can do this yourself by opening the monitor (not so easy so be carefull not to break anything), remove the print with the buttons on it and clean up the metallic pollution that sits on the black plastic outside of the little buttons. That kind of pollution causes a short circuit into the print in an unpredictable way. This is also the reason why pressing the buttons has no effect anymore. The problem has gone for about 8 months and today it is back, so it seems that there is a production problem with the buttons. The metallic pollution is, so it seems, self regenerating, maybe due to electrolyse or something like that. I hope this explanation is helpfull for all other users with the same problem. Good luck!!
Posted on Jul 11, 2007
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Mar 07, 2011 | Neovo F-417 17" LCD Monitor
My ag neovo e-17da monitor everything in the screen seems to have stretched and the bottom of the screen where the arrow is to scroll up and down i cant see it its like i need to shrink the display a...
Hello Dean,
It seems your windows resolution settings are set wrong, you simply need to adjust the resolution to match the monitor. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or Adjust Resolution from the left column(Vista/7), now find the slider bar for resolution and slide it to 1280x1024. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts/icons too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply buttons simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps FixYa,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Jan 02, 2011 | Neovo E-17 17" LCD Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
My Neovo f-417 LCD Monitor is switching off after 3-4 seconds. Green lamp is still blinking but there is no ligts and picture on screen. Only black screen
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Sep 23, 2009 | Neovo F-417 17" LCD Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Monitor shows cctv for 2 seconds then goes of? Why.sx 17a monitor
Dear sir pls match the colur system standard of CCTV out & ur monitor Video in , U might be using a PAL camera on NTSC input or vice versa
1) ur monitor may not be supporting low resolution try NTSC/PAL to VGA convertor box ..
Mar 20, 2009 | Neovo AG 17" LCD Monitor
Neovo F-419
I'm had the exact same problem. Try to go to DISPALY PROPERTIES in XP and change the screen resolution to 1024X1280, the screen will reset itself and the square box will disappear. try to do it more then one time if it's doesnt help at first time. after awhile u can try and bring it back to the original resolution.
Good Luck
Jul 19, 2008 | Neovo F-417 17" LCD Monitor
Occasional Distortion
For some time we used to sell these monitors in our store. Some of these same models do have a defect which can cause some of the problems you all are having. Neovo does come with a good warranty, at leasted they did when we sold them at the store lasting at least 3 years. We had a monitor that had random blue stripes which Neovo replaced. One thing you may want to try before throwing in the towel on your monitors is reloading the device drivers on the montor. These monitors came with a CD. If you cannot find it you can get the drivers from here http://driverscollection.com/?H=F-419&By=AG%20Neovo . If you think you are still under warranty, give Neovo a call they will may just replace your monitor with a new one. Good luck....
Jul 10, 2008 | Neovo F-417 17" LCD Monitor
Garbled screen on Monitor
Have you tried a different monitor? It sounds like your have a faulty Video card.
Dec 31, 2007 | Neovo F-17C 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
3,397 people viewed this question
Top Neovo Computers & Internet Experts
Steve Allison
Steve Allison
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
