Question about Echo Garden
How does the oiler work on a echo cs440 chainsaw
How does the chain oiler work
  • John J Davis Feb 22, 2012
    I flushed the oil tank, blew the tubing out with air, adjusted the screw min/max and it still will not pump oil.
  • John J Davis Feb 25, 2012
    Finally got the oil pump off and found the problem is the pump shaft in the oil pump which runs off the spiral screw off the main shaft was stripped or ruined. Consequently the pump will have to be replaced.
    Sergeant:
  • 316 Answers
Hello, depends on the model you have, mine has a gear drive,and others are gravity flow,there is a inside tube with a filter that drains to the out side for oil,hope this helps.
Posted on Feb 23, 2012
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
  • 211 Answers
SOURCE: chain oiler replacement
If it is Stihl 025 the chain oiler is on the bottom.First check if the worm gear(under the starter)is in good condition.Replace the starter(blocking the piston in the cilinder with a rope with many nods,that rope entering in the sparkplug hole).On the handle there are 4 screws on the right side (under 4 black plastic plugs,at the bottom 2 screws.)CUnlock them and take off the handle.At the bottom you can see the chain oiler( under the hose) the mark for right possition is there.Take off the oiler using a screw(lock clockwise into the oiler)and then pull it out.Clean with compressed air the oil hole.Put back together .Succes!
mihai71
Posted on Dec 01, 2008
  • 211 Answers
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Posted on Dec 15, 2008
  • 205 Answers
SOURCE: chain oiler
Saw dust has clogged the passage way in the bar. take the bar and chain off and clean the groove where the chain runs, also near where the bar mounts to the saw there are holes in the groove that intersect with cross holes in the center of the bar, push a paperclip through top and bottom.
If this works for you please leave a rating, thanks
Posted on Mar 25, 2009
  • 4088 Answers
SOURCE: chainsaw oiler leaks oil out case and no oil on chain
Take the bar and chain off--run the engine--the oiler port from the case should discharge some oil. If none, you have trouble with the oil pump or the tubes to and from it. The oil tank may be leaking at the tank opening for the pickup tube. If oil appears at the oiler port, then there may be dirt/blockage within the oil passages in the bar end. Clean with compressed air.
Posted on Jul 04, 2009
Chain slipping
Resistance through the guide bar may be too much for the clutch assembly to cope with. Trust you have plenty of chain oil running through the chain and guide bar. If not, resistance will increase creating heat and eventually smoke, ultimately permanent damage to the parts. Ensure the oiler is working.
Jul 14, 2014 | Echo Garden
ECHO 452VL NOT OILING CHAIN
Sounds like you have a blocked oil pump. With the flow regulator fully open and no cage filter on the end of the oil intake hose its probably pulled through dirt and blocked the pump.
Jul 27, 2013 | Echo 452vl 452 guide plates
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
Feb 19, 2013 | Garden
CS440 treads in cylinder head for spark plug appear to be stripped. Treads chasing tool doesn't help. Is there a way to re-tap the head and insert a sleeve to repair this wonderful saw? Any...
A good machine shop will fit a 14mm heli coil into the torn threads, this will make it as good as new, in most cases stronger than the original thread.
Sep 19, 2011 | Echo CS400 18" Chain Saw
Brand new chain saw bought from reputable dealer. The CS600. It was missing a part on the oiler and dealer fixed. Now the clutch overheats badly, to the point it acyually smokes. Does Echo have a policy...
Not had a lot to do with Echo, but have always heard good reports, for smoke to come from the clutch cover the clutch would have to be slipping, either due to running with the chainbrake on, or useing with a very blunt chain. To make sure the brake is off, pull the hand guard fully back to the top handle.
Apr 04, 2011 | Echo CS600P Gas Chainsaw 20 Inch
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
257 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
