Question about NetGear WGR614 Wireless Router
Unresponsive wireless broadband virgin media
When trying to access the internet without the Ethernet cable, the internet is unresponsive. My computer is able to identify the connection and appears to connect successfully. I am also able to access the internet when plugged straight into the router. I can't get in touch with Virgin media as for some reason they want a security answer which to our knowledge has never been set up.
  • hvincent Feb 22, 2012
    I have tried many times to reset the router and have tried turning off my firewall temporarily.
  • hvincent Feb 23, 2012
    Another thing to add might be that the two other people sharing my house have no problems getting a wireless connection.
    Master:
  • 451 Answers
Please login to your browser via 192.168.1.1 and change the wireless channel to either 1 or 11.
also if your wifi encryption is set to WEP please change it to WPA2 or WPA.
Posted on Feb 23, 2012
  • 2 more comments
    Thanks. I'm afraid I'm not that technically savvy just yet How do I go about doing this?
    Thanks. I think it's set to WPA2. Under properties > security, it says WPA2-Personal. I have also looked up the DNS via Thomas Durr's method (shown below) and it says I have a 192.168.0.1 server... Not sure what to do with that information though.
    Does it matter that the IPv4 address says 192.168.0.5 ? The default gateway and server is still 192.168.0.1
  • Tony Feb 23, 2012
    sorry some reason i thought you had a linksys. Anyways some routers have different IP address settings. I think the easy solution for you is to just reset the router to factory defaults to do this hold the reset button in on the back of the router with a paper clip for 30 seconds with it powered on. then setup the wireless network settings and encryption and try again.
  • 20 Answers
SOURCE: NETGEAR WGR614 Wireless Router keeps beeping
try by upgrading the latest firmware version from netgear website
Posted on Dec 16, 2008
  • 10 Answers
SOURCE: Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Posted on Jan 28, 2009
anandg27
  • 1272 Answers
SOURCE: want to get more speed out o my fiberoptic broadand
Well the best router for your connection type would be WNR2000. Even Virgin media recommend this router for their 20 and 50 Meg connection. I am pretty confident that this router will meet your requirement with this ISP connection.
Hope this helps.
Posted on Oct 13, 2009
Testimonial: "Excellent advice!"
shishirgarde
  • 114 Answers
SOURCE: I have lost the security key or password to
1) Wire your laptop to your router and restart it once.
2) After the restart, go to Run, type cmd
3) Once in the command prompt, type ipconfig
4) In the ipconfig information, there would be default gateway, type that in your internet explorer.
5) It will ask you for username and password. Usually, its "admin" and "password". You can also try "admin" and "admin"
6) Once logged in, look for a wireless tab and under that, security.
You will be able to find your key there.
To have more precise info, you can tell me your router model number.
Posted on Nov 01, 2009
redhaze89
  • 854 Answers
SOURCE: i have a netgear wgr614 v9 router but have
you to port forward. call Sony tech support to ask what port to be forwarded using Netgear router. Then follow this steps below...
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Apr 21, 2010
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
Ethernet cable not working
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
May 25, 2009 | Dell Inspiron 6400 Notebook
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
I having problems connecting a netgear 54 rt usb adp router to virgin broadband.Router is saying there is an internet connection but computer displays cannot display page and no connection.PS3 has picked...
on your computer try to reinstall the device driver for wireless. try to connect the ethernet cable directly to the computer. if you have internet access, then most likely your netgear router needs to be reconfigured. you need to contact your internet service provider or router manufacturer for the reconfiguration of your router. mostly likely the security settings of the router needs to be changed.
Sep 16, 2008 | Computers & Internet
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
Buffalo WHR-G54S & Virgin Media
Just to let you know if you havent solved it yet, i had this same problem today and i fixed it by pressing the reset butoon on the modem, this was after hours of trying to reset the router
Mar 20, 2008 | Buffalo Technology WHR-G54S Wireless...
Wireless connection
The first step to try is to reboot both the router and the cable/DSL modem. Turn off your computer, and unplug the router and the modem from the mains. Wait one full minute, then plug the modem back in. Wait until the lights stop blinking (until it indicates a steady connection). Once that is complete, plug the router back in, and wait until it also stops blinking. Once the router and modem are both back on, then turn your computer back on and check to see if you have a connection. If that doesn't work, then take the router out of the picture -- plug a computer directly into the ethernet port on the modem. You should definitely have an Internet connection at that point. If it works, the problem is in the router. If it doesn't, you'll need to call Virgin Media's help desk for assistance.
Sep 29, 2007 | Belkin (F5D9230-4) Wireless Router...
NetGear WGR614 Wireless Router Logo
94 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
