Question about Gateway FPD1975 19" LCD Monitor
Gateway mx3215 freezing on init boot
I have a Gateway mx3215 when turning it on it freezes at the gateway bios boot screen. It allows me to enter the bios settings or if I hit F10 it allows me to select the boot drive, then I can get it to boot. Once in windows XP if I click on the start menu it forces the computer to shut down.
I have the computer set up to dual boot linux, When I can get the computer to boot and get linux up it runs linux fine with no problems.
Is my problem bios going bad, cpu going bad? is there a way to flash the bios?
  • T_Aubuchon Oct 28, 2008
    I actually solved my own problem.
    I discovered that the U key on the keyboard was sending a constant signal to the computer, causing it to get confused on boot up etc. once I fixed the U key the problems stopped
  • fmr888 May 11, 2010
    default your bios back to orginal settings. Hit the F5 or F8 to get a set up screen. stay out of the bios.let me know what happens.
    Master:
  • Gateway Master
  • 534 Answers
Corrupted driver or faulty hardware perhaps.
Posted on May 08, 2017
pastorm
  • 98 Answers
SOURCE: Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Posted on Aug 09, 2007
ginko
  • 19396 Answers
SOURCE: Notebook will not boot
You need to get a windows install disk
Posted on Mar 08, 2008
  • 55 Answers
SOURCE: Monitor won't turn on, just keeps flashing the gateway logo on and off
Unless there is inadequate ventilation, your monitor could remain on all the time with little ill effect. Actually turning on and off your monitor actually puts more strain on it then leaving it on all the time.
If the gateway screen is displayed for a moment and then just turns off, I believe the inverter board inside the monitor has broken.
What's actually happening is that somewhere in the board more voltage then needed is "leaking" in and the safeguards on the board turn it off to prevent damage.
I would go and get an estimate from a shop. If the price is within 30-50 dollars of a new monitor, get a new one.
Posted on Mar 15, 2008
farhangM
  • 64 Answers
SOURCE: gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Posted on Dec 12, 2008
SOURCE: Notebook Gateway 7330GZ won't boot
hold f8 (or  f10) on boot up...  select menu item: boot from last good configuration
Posted on Mar 10, 2009
Can Gateway MX3215 boot to usb stick?
If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
Nov 13, 2011 | Gateway MX3215 Notebook
I have a gateway gx7022e windows xp computer. When i try to boot it up the white letters pop up then the screen goes to the gateway screen and freezes. Then my num lock comes on but my keyboard wont work....
At power on / power up, look for the key during the bootup (black screen with white text), that allows you to enter SETUP. If none designated such as F1, F2 F10 etc, then quickly click the delete button a few times and that may get you into setup. You may have to turn off the computer if you miss that window of time if it rfequires pressing the delete button a few times. Keep an eye out for the Enter Setup key though. To turn off the computer press and hold the power button 'till is shuts down and resart the process until you get to the setup screen in bios. In setup bios environment, look for set factory defaults and then save and restart. That may solve the issue of the lockup.
Jan 10, 2011 | Gateway GX7022E (RBGX7022E) PC Desktop
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
My cursor freezes and the screen goes blank. The
Try to update your machine's BIOS. Download it from the internet (search for the Gateway drivers - bios).
Jul 01, 2009 | Gateway M-6843 Notebook
HOW DO I PUT ON A NEW OS?
you need to use the the installation cd of the OS (Operating system, eg.Windows) you want to install into the computer. insert the cd and you should get a message to start from cd.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
May 21, 2009 | Gateway MX3215 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
May 23, 2008 | Gateway 7330GZ Notebook
450sx4 freezes half way thru setup
E-mail CHID: 5736 So basically it freezes trying to intialize the setup. ... try rebooting the computer into safe mode and run the setup through safe mode.
Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Gateway 450SX4 Notebook
Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Sep 29, 2007 | Gateway MX3215 Notebook
Gateway FPD1975 19" LCD Monitor Logo
103 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
