Question about Dell Inspiron E1505 Notebook
Laptop will not charge battery
E1505 ac adapter provides power, but will not charge new battery. Did one then failed
  • Anonymous Dec 18, 2008
    Uhh... your solution is not helpful. It isn't the battery, because at first, my power cord would work sometimes and sometimes it would say Plugged in, not charging. It would bring up a notice saying "Power source unidentifiable, please attach a Dell somethingsomething adapter." It is a dell adapter, however it refuses to charge because it cannot identify it as a Dell adapter. It came with the computer...
    It's not the power cord, because it will power the computer, just not the battery...
    I'm not sure about solution #3, but it is the original battery and charger...
    I don't want to pay Dell $169 for a new charger since I'm not even sure that is the problem, and if it broke once, it might break again.
    I've Googled this topic, and the results are far from encouraging.
    I have a sneaky suspicion that the computer won't charge simply because it cannot identify the power source as Dell. Figures.
    Problem Solver:
  • 14 Answers
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Posted on Oct 27, 2008
Dell 1505 laptop..amber light flashes constantly, battery shows 100% but when I unplug AC...no power
Hi there!
The problem you're having there is a motherboard issue,
The computers power button is amber and it flashes that means the power inside the computer is not being distributed properly. You said that the battery is 100% charged but when you unplug the AC the computer will have no power, that means the motherboard is failing, its not identifying the battery as a source of power anymore,
You can try to use another ac adapter and check if the computer will boot up, or try to unplug and plug the memory and hard drive see if any changes will happen,
If the computer turns on with another ac adapter and boots up to windows properly then try to update the bios.
If the ac did not also the memory and hard drive,.
You'll really need to get a new motherboard.
Hope this helps!
Apr 03, 2010 | Dell Inspiron E1505 Notebook
Battery will not charge. The battery is new, verified on another laptop and it works fine (takes a charge). Unit works fine when connected directly to AC. The laptop is a Dell inspiron E1505. How do I...
This isn't easily done. Have you recently replaced your power adapter for any reason. I've found that some laptop batteries won't charge if the charger is just slightly different from the original one, even if it's another Dell power adapter. If you haven't replaced the power adapter recently then it may be that your female power jack isn't properly seated or soldered into the motherboard. To reseat or resolder the jack with require you do completely dismantle your laptop. If you're not confident it doing this, then don't try it yourself. Also, resoldering the jack isn't as easy as it would seem either. Before doing any dismantling, remover your battery, turn on your computer and gently wriggle the adapter around in the female jack of the computer. Does your computer shut off on you? If so, then you definitely have power jack issues. See madhattercomputers.com
Mar 13, 2010 | Dell Inspiron E1505 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
My Inspiron e1505 does not charge the replacement battery Gd761
The problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Computers & Internet
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
AC Adapters in laptops
It is not a special chip that dictates if a charger can charge a certain laptop, but these two factors:
1) You need to have a power adapter/charger with the correct voltage and amps. Some common Dell laptops use 19.5V (volts) and 4.62A (amps). I have seen some Dell adapters with 3.34A (amps) as well. If you use an adapter with the wrong voltage and amperage, you could cause damage to the laptop's power supply and/or motherboard...or it just won't work at all.
2) The type of connector to the laptop. Different manufacturer's use physically different connector sizes and shapes. Some are larger and circular with a pin in the middle, while some are smaller with no pin. It depends on the laptop.
You can look at the voltage of the original charger on the brick part (the middle of the cord that looks like a brick). Make sure you get one that matches exactly.
Mar 19, 2009 | Dell Inspiron E1505 Notebook
Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Jun 21, 2008 | Dell Inspiron E1505 Notebook
Not charging
Make sure you are using a 4.62A Power Supply (90watt) some of the knock-offs are only 65w (3.34 A). And you will never have enough current to charge the battery.
It will only run the laptop, but not charge.
The mobo sounds like it is good, if you had a power issue, you would have orange lights or blinking, and it would not come on at all with any power supply.
Mar 31, 2008 | Dell Inspiron E1505 Notebook
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Dell Inspiron E1505 Notebook Logo
395 people viewed this question
Alun Cox
